M4 or M3 flat top / buzz cut?
mmitchell_houstonmmitchell_houston Posts: 2,533
edited April 2017 in The Commons
Think J.Jonah Jameson, not just a skull cap. I have one already, but it's not quite looking the way I want it to. I'm planning to use this iN Poser, and would actually prefer an old-style geometry-based hair to a hair-strand file. Any recommendations would be greatly appreciate it.
Post edited by mmitchell_houston on
  • Alley RatAlley Rat Posts: 406
    I like this style a lot.
    https://www.daz3d.com/morphing-flat-top
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Not sure if this works, but I use this one often
    https://www.daz3d.com/flat-top-hair-for-genesis-and-genesis-2
  • I like this style a lot.
    COOL. This is what I'm looking for. Anyone know if there is an M4 fit?
  • OdaaOdaa Posts: 1,548
    Any hair (well almost) can be fit to any figure by parenting it to the head instead of fitting it to the figure, and using the y-translate and x/y/z-scale functions to get it to fit.
    Thanks for the tip. I prefer to save time by purchasing something already created specifically for the figure I'm using. But, when I can't find what I'm looking for, I will definitely start mixing and matching.
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    I have a similar issue.  I'm trying to get Daryl hair (M3) to fit genesis 3M.  I worked with the x/y/z functions and was unable to get a good result, but I am a complete newbie so it is probably due to lack of knowledge/skill.  Does anyone know whether "wear them all" for gen 3M is the right product to make the Daryl hair fit gen 3?
  • xyer0xyer0 Posts: 6,448
    @Worlds_Edge ytran - 0.61, ztran - 1.26, xscale - 93.2, zscale - 111.1, subdivision applied (select hair/item in Scene tab, then Edit>Figure>Geometry>Convert to SubD).
    I have Wear Them All, but I just loaded the hair with Michael 7 selected, and it parented itself (no Autofit dialog box appeared, nor was there a right-click option for "Fit to").
    2111 x 1340 - 4M
    It does work well with Michael 7, I hadn't tried that.  I'm trying to fit to genesis 3 M.  I used the numbers you gave me and they are certainly a better starting point than what I had before.  I'll keep playing around with them.  I'm not sure what subD is, but I will research and try it, thank you!
    You also say that you have Wear Them All - am I correct that its purpose is to do what I want to do?  In case I'm not successful, it's always good to have a backup plan.
    I've seen a couple on rendo for m4 but they all seem pretty expensive.
