daz big cat problem iray render
in New Users
hello,
i install big cat , real fur and LAMH free player , and i do not have a good image , no material, no texture ! ( i attached a picture)
thanks for your help !
LAMH hair has to be saved out as Fibrehair or a .obj and applied to the big cat before it will render in Iray.
Plenty of help in this thread.
http://www.daz3d.com/forums/discussion/14818/look-at-my-hair-lamh-official-thread-update-1-6-0-1-released#latest
thank you!
Don't forget, the materials applied to the hair should be manually converted with the Iray Uber shader. If you let the automatic conversion do it, you can't really control or reliably adjust what comes out.
thank you !
hello,
i have "real big fur for big cat" and free player ,so, big cat stay white even i apply "iray uber base ".
thank for your help!
That looks like the critter materials haven't been applied to the LaMH hair groups. Keep the groups selected and switch to the Surfaces pane. You might find the hair is still untextured.
Have you tried rendering? Whether it's LaMH hair in 3Delight, or converted Fiberhair in Iray, what you see in the Viewport will be very different to what comes out in a render.
