Who can I see the difference between RSL and MDL before load something?
Super cheese sandwich
in New Users
Who can I see the difference between RSL and MDL before load something? I have attached an image
Thanks!
They should be tagged. A layered image preset isn't usually engine-specific, there may be one in each set of sahders for convenience.
To add on, I just had this problem too. Sometimes the Material doesn't say what engine it's best suited for. When I change to the TAG tab, it says there what is what.
Not that sort of tag - there should be a marker, RSL or MDL ((3Deligh or Iray respectively) on the thumbnail. Please report the sets wheer that is missing from the material(s) or Shader presets. As I said, I don't think the Layered presets necessarily differ though if they do that too should be reported.
If you expand the Materials category, you should see a subcategory "Iray" specifically "Iray/Wardrobe" to separate out the Iray materials. I must have added the RSL/MDL material tags myself.
