Who can I see the difference between RSL and MDL before load something?
Who can I see the difference between RSL and MDL before load something? I have attached an image
Thanks!
193 x 132 - 21K
  • Richard HaseltineRichard Haseltine Posts: 111,382
    They should be tagged. A layered image preset isn't usually engine-specific, there may be one in each set of sahders for convenience.
  • Griffin AvidGriffin Avid Posts: 3,884
    edited March 2017
    To add on, I just had this problem too. Sometimes the Material doesn't say what engine it's best suited for. When I change to the TAG tab, it says there what is what.
    588 x 924 - 283K
    Post edited by Griffin Avid on
    Not that sort of tag - there should be a marker, RSL or MDL ((3Deligh or Iray respectively) on the thumbnail. Please report the sets wheer that is missing from the material(s) or Shader presets. As I said, I don't think the Layered presets necessarily differ though if they do that too should be reported.
  • LindseyLindsey Posts: 2,017
    If you expand the Materials category, you should see a subcategory "Iray" specifically "Iray/Wardrobe" to separate out the Iray materials. I must have added the RSL/MDL material tags myself.
    487 x 563 - 223K
