Can't install Aiko 4
surikisuriki Posts: 0
Hi there!
I just bought the Aiko4-Pro-Bundle.
After installing all the files, i cant choose any new files in DAZ Studio.
I still got both Victoria-Modells and the basic genesis, male, female and kid figures.
I already tryed installing it multiple times and i launch the bundle right after installation (as it says it is needed).
Do you have any idee why this doesnt work for me?
wbr, Daniela
  • frank0314frank0314 Posts: 14,763
    They won't load or you can't find them?
    edited January 2013
    Aiko 4 is not a separate figure, it is a morph of V4, and you need to inject it as such, as you would inject Morphs++ into V4.2
    Post edited by Chohole on
  • surikisuriki Posts: 0
    Hi there!
    I already tryed reinstalling all Files.
    I set my installation-folder to c://daz studio/ and the contentfolder to both c://daz studio/ and c://daz studio/content/.
    After installing DAZ Studio, i installed Victoria to c:/daz studio/.
    'She' looks healthy and works well. :P
    After installing her and additional Victoria-Content i tryed to add Aiko to the folder c://daz studio/.
    This folder is the only one i can choose without getting the answer "A requested file is not found in this folder". Thats why i assume c://daz studio/ is the right folder to install Aiko to.
    However, Aiko does not appear in DAZ Studio. Neither in the Content Libary nor in the 'Smart Content' or 'Shaping'-Area to the left.
    Installing Aiko has no effekt.
    wbr. Daniela
    Hi,,suriki,,, you may better to discribe more detail,,
    what version daz studio you installed?
    and you use PC or Mac, ? .
    installation-folder to c://daz studio/ means you install daz studio aprication there?
    then,, daz contents folad is c://daz studio ??
    so that means you have installed aprication and contents same folda? :roll:
    and,, you must not make daz conents folda, as sub folda of daz contents folda..I think. ^^;
    You better first check to install documents more,, or ask everything for clean install, in forum,
    (I think you better to ask everything in new user forum,, step by step ,,,
    and try again to uninstall ,, install contents.
    Start setting is so important for you to enjoy ds and ds contents.
    you are lucky because,, you have not so many items still, I think,,
    so it is not so heavy work.
    i think,, you can find Aiko4.cr2 though Aiko4 is morph for victoria.
    have you installed Power loader too?
    I seldom use INJ or REM files when use Aiko4 or VIctoria4 Elite morphs, or Victoria morph ++
    open content library tab from top menu,
    then poser format>Your content folda for poser>Figures>DAZ people.
    there should be Aiko4.cr2 if you have installed AIko4 correctly.
    can you see other cr2 files ? (eg victoria4.cr2 )
    and can you stick your pic of Content library ? it may help you to find what is wrong.
    987 x 429 - 82K
