Adding to Cart…
This Toon Cow https://www.daz3d.com/toon-cow ? That's a DS format item that imports with the DSON Importer - if it does something but fails to load the figure that usually indivcates that the DSON files (the main package, not the PoserCF package) were not installed or were not installed to an available Poser library folder (the Data folder from the main zip should be in the same folder as the Runtime that Poser uses, which will be the folder whose name appears in the Poser Library panel).
