Dynamic Cloths that go right through the floor
Hi everyone. Been having this problem for quite a while now. My dynamic cloths nearly always go right through the floor when I drape them. This happens even when I specially ask DAZ Studio to let the cloths collide with the floor. Anyone else got this problem as well? And does anyone know what to do about this? Thanks!
  • FSMCDesignsFSMCDesigns Posts: 12,855
    happens to me also. I find that it really depends on the density/makeup of the floor plane AND how many other things in the scene it has to collide with. I usually add another flolor plane for it to colliide with and play with different densities and in most cases this fixes it.
  • Im assuming that your using OptiTex. As I recall, the dynamics look for vertices so if you have a plane with very few vertices, the clothes are going to fall right through. Increase the number of divisions you have in the plane. Or, if you are using a set, try what FSMCDesigns suggested, place a plane underneath the floor of your set so the dynamics can detect that. Be careful how many things your dynamics are colliding against, I think that if too many items are detected for collision, it will overwhelm the dynamics and theyll just fall through everything.
    Somewhere in this mass of information there is a good posting regarding Tips and tricks for dynamics but I couldnt find it...
  • ButchButch Posts: 800
    Placing the plane a smidgeon above the floor will work, too.  Just hide the plane in the scene tab - the fact that it's hidden won't effect the collision.
  • K T OngK T Ong Posts: 486
    I did as you fellas suggested: placed a plane a tad above the floor with more than 200 divisions, plus reduced sharply the number of things the cloth collided with. This time the cloth behaved well.
    Thanks, fellas. You rock. :)
    Just to add to your fun, you can use primitives for all sorts of things with dynamic cloth.  The attached image uses a flattened cylinder (hidden), using an animated drape to push the fabric upwards.
    1000 x 1414 - 2M
    LOL! A strong gust of wind perhaps?
  • nicsttnicstt Posts: 11,715
    Sometimes a default plane with no extra verts will work well; I start with those, and if it didn't work tried adding extra vertices. I don't use Optitex anymore, but an alternative.
    LOL. Might try and experiment a little to see if I can reproduce that effect. :)
