Carrara 8.5 Questions
Headwax
Well I've finally finished all my non personal projects using car 8.1 and can move onto Car 8.5.
I spent a few hours watching PhilW's excellnt "what's new in Carrara 8.5."
I'm presently suprised on the autofit stuff and the fact that most of my 4th generation body poses come close to working.
I haven't been able to get smart content up and running so am presently reinstalling Daz Studio to see if that works.
But my first question about 8.5 is:
With eg Genesis, how do I mix in two different full body morphs - eg The Basic Child and The Gorilla? (solved thanks Stezza)
thanks in advance.
cheers :)
Post edited by Headwax on
Depending how large your content is it may take a few minutes for Smart Content to load... PITA!
Just use the sliders under Actor/Parameters
Slide the Basic Boy
then slide the Gorilla
thanks Stezza, I found the child slider but I thought it vanished with the gorilla one - will go and have another look see ,
okay, thanks for that :) !
Question 2 :) (solved thanks Stezza :) )
Can I load up a new Uv set for genesis using Carrara or do I need to go to Studio first?
Daz says
Question 3: SOLVED: THANKS STEZZA
If I buy this product https://www.daz3d.com/v4-and-m4-shapes-for-genesis
Can I use eg M4 morphs I own on Genesis?
Do I need another product to use K4 morphs in Genesis?
thanks muchly again in advance :)
edit: I found this for question 1
You need to start here for G & M4, V4 and add on what you need for V3,V4, G2 & 3 and use the DS plugin to get them show up in Carrara
well worth it once you get used to it... though I've ended up with an abundance of morphs to the point where I've got morph overload lol
Thanks again Stezza ! :)
for your UVs
I just apply any M4/V4 textures to Genesis male/female figure from where they reside ( usually in my Poser structured folders ).. the usual fixups need doing but using Fenrics tweakers comes in handy there.
Applying G2 textures to G2 however I have to do manually most times....
edited again..
after loading a texture and getting it to my liking I will drag the global shader to my shader tab for future use.. saves doing it all again.
It is a really great feature of how you can mix sliders for looks! I am a big fan of Sickleyield's die trying morphs FREE on ShareCg (hope it's OK to post as it's free stuff)
It would be great to have them for G3.... sigh.....
Silene
http://www.sharecg.com/v/72792/gallery/21/daz-studio/dietryings-182-morphs-for-genesis-2-female G2 Female
http://www.sharecg.com/v/73186/gallery/21/DAZ-Studio/DieTryings-182-Morphs-for-Genesis-2-Male G2 Male
http://www.sharecg.com/v/58198/gallery/21/DAZ-Studio/DieTryings-182-V4-Morphs-for-Genesis (DS4 Genesis conversion of DieTrying's 182 free morphs from V4 to Genesis.)
Also, as I am envious of the facial expressions for the G3 characters...you can buy a package of mix/match facial expressions for G2 (and earlier) One for males and another for females by Elisa Griffin in the DAZ shop. It does give more facial expression than the bog standard ones, but are a bit fiddley to use.
https://www.daz3d.com/gryffnn-elisa-griffin-1
Oh and I just found these G2 high-level facial expressions by cakeone In my basket today!
https://www.daz3d.com/more-expressions-for-genesis-2-male-s https://www.daz3d.com/more-expressions-for-genesis-2-female-s
Thanks again Stezza for the quick answer.
I was playing a bit and found if I load basic child then add k4 textures it works well and I can load up a basic woman morph and the K4 textures still sit well???? Must check again tonight.
thanks for that Silene, that's also the kind of information I need :)
The following is an old thread, and it follows no logical order, but it does have answers to several questions and work arounds that I encountered when I made my own migration from 8.1 to 8.5. Eventually, I was very glad that I did. Most important thing, you will occasionally get a topology protection warning for genesis and genesis 2. I started ignoring it. Have yet to suffer a bad consequence for ignoring it.
http://www.daz3d.com/forums/discussion/45361/best-practices-using-genesis-and-genesis-2-content-in-carrara/p1
also Carrara tools from Inagoni are very helpful ...I like the shaper tool to help fix pokethrough on a lot of stuff
thanks fo that Dioemede, looks like a wealth of data - obliged :) will check it out,
Stezza wrote
thanks Stezza, I think that's the only one I dont have! thanks for the recommendation
in order to re install the order that I am just going through is
DIM
PostrgeSQL
DAZ Studio
Carrara
Remainder of content.
I have been successful in this currently and have anouther 5000 items to finnish downloading with DIM.
thanks Chickenman
PostrgeSQL ? I need to look at it.
I have uses dim to download all my genesis stuff
I have reinstalled Studio to latest version and run it and it tells me CMS is running- yet when I look at my task list it is not running - windows 7.
Carrara 8.5 tells me it cant contact cms - so I havent got the smart content up and running - though it has worked previously
so running PostrgeSQL would help? I havnt had a chance to read up on the Valentina stuff.
smart content does not work for me at all
in DAZ studio either
I just browse through my library in both apps
the content tab where you add runtimes can also add the DAZ studio my library folder and see the duf files
you need to download PostgreSQL conversion tool and PostgreSQL CMS via the DiM
maybe that's why your Cararra smart content ain't working
also after that you may need to reimport the database metadatas in DS for it to show
thanks Wendy and Stezza once more :)
I like how getting it to work is so clear and easy :) thank Heaven for this forum
well I can have 5 or 6 instances of Postgreysquirrel running in Task manager and still my smart content is dumb
it works, just not smartly, is rather useless as does not filter by selection etc
obviously my database works as search in D|S works and product lists etc
I am unconcerned, just pointed out you do not need to use it
I think having it in my 4.9 beta with 4.7 using Valentina may be the reason.
thanks Wendy, just feeling my way around,
I havnt used Dim before, it was fairly painless for the Genesis stuff, but of course I have no idea what I have :)
Had a win today - trying to bring in a Genesis Child that was dressed in V4 clothes from studio (the clothes wouldnt fit properly in Carrara) I was getting the could not find Genesis.duf error blah blah
so I had a light bulb moment added the genesis folder into my browser (not runtime) - and presto - no more error (so far)
Today's Question Any way of making Genesis actors default rendering smoothness a 1 as opposed to a 2?
thanks in advance :)
