SOLVED Help with "TOON Generation" hair
eyeseeeyesee Posts: 172
edited March 2017 in Carrara Discussion
I've tried everything I can think of but I cannot get hair to parent to a toon generation figure. If I move the chest the hair stays in place and doesn't move.   crying
Post edited by eyesee on
  • HeadwaxHeadwax Posts: 10,562
    hmm yes, try turning it into an object
    via select hair
    Edit>Smooth
    then with the hair's model selected do
    Animation>DetachSkeleton
  • eyeseeeyesee Posts: 172
    Afraid it still will not parent after trying your changes Head Wax
  • PjotterPjotter Posts: 274
    I assume you have parented it to the head? (if it is head hair).
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,386
    where are the hotpoints of the hair and head and can you press capslock and change them?
    I am rendering so cannot check, I have the bundle, I know it has a few issues.
  • LindseyLindsey Posts: 2,016
    All of the Toon Generations hair I have are conforming figures.
    1. Select the hair
    2. Parameters tab click on Fit to
    3. Select Base Figure from the drop down list, click Accept
    The hair should attach itself to the Toon Generations figure's head if it wasn't currenly on it's head.
    1099 x 927 - 354K
    1. Select the hair
    It does "fit to" but moves away from the head when I move the chest. Doesn't do this in Daz Studio though.
    edited March 2017
    Pjotter. I've tried parenting to Head, Base figure and the model none of which works. Even tried setting up in Daz Studio and importing but only the skeleton came across.
    The hotpoint is at the hips, but it does have a head entry in the hiearchy.
    try capslock and move the hotpoint to the head then parent it
    As soon as I put "fit to" the hotpoint moves to the hips from the head and still stays put when I move the chest
    Got it to work without the "fit to". Thank you wendy.
    eyesee said:
    Lindsey said:
    ... snip ...
    Opps, wasn't paying attention and didn't notice this is the Carrara thread.  Glad you were able to resolve your issue...!
    That's OK Lindsey, all help welcome.
