problem with a face graft texture match
Hey. I had a problem with the texture match. I created a face graft prop copied all the texture settings to the face of the genesis on the Prop. But the renderer did not find a texture match. And how is this corrected?
  • Richard HaseltineRichard Haseltine Posts: 108,866
    a) is the GeoGraft UV mapped, in a way that will allow the textures to fit?
    b) if that is OK, did you apply the base shader? Copy/paste does not set the shader, it just copies parameter settings.
  • va-silyva-sily Posts: 52
    The texture is the same as the uv map. The base shader also assigned. But the renderer does not match the color of the texture. I can not find the reason.
    I used all possible ways. But the problem remains the same. The texture and the map are matched. The shader is applied as a daz default. what am I doing wrong.?
