3Delight has that Iray doesn't?
13»
  • Stryder87Stryder87 Posts: 899
    The Emissive shaders alone made it a must-buy for me!  Grear stuff.
  • MarshianMarshian Posts: 1,465
    Very good! In the render below I lit the figure with emissive planes that are just outside of camera range- a 3 point setup. The shadows are so soft, love it!
  • IvyIvy Posts: 7,165
    edited March 2017
    Marshian said:
    Hi Ivy! I haven't been able to figure out how to get all the maps to transfer from Iray to 3Delight- such as cutout to opacity. If you view the surfaces next to each other there are quite a few channels that are different. Do you think it would be acceptable for most people to transfer those manually? Maybe this would take some script writing, which I haven't done.
    Hi  Marshian I am manually doing it now..lol
    though there is a freebie IrayTo3Delight conversion script that timmins.william,& Esemwy did that seems to to work pretty good I still have to manually do the trans maps and cuts outs but over all not bad. the reason I need a conversion script is because i like iray but not for animation I like the control I have much better with 3dl  for dramatic lighting effects
    here are 2 animations I did . the first one is a Iray one the second one i just completed using 3dl.   to me using 3DL i can make animation clearer less pixalation .  I also can render it much faster and use a lot more props with 3dl over iray .
    Iray animation
    3Delight animation
    those are my reasons why I prefer 3dl over iray....For now anyway I am still learning iray  Ive been working with 3dl for years
    edit:  opps forgot the animations comparisons..lol
    Post edited by Ivy on
  • kyoto kidkyoto kid Posts: 41,983
    ...manual  conversion can be a real PITA particularly for a large scene set, though when done, you can save it as a materials preset afterwards.
  • Oso3DOso3D Posts: 15,090
    Ivy: Cutouts? Are you sure you have the most up to date script? One of the big goals with that script is not having to redo all the opacity maps?
    yea  I believe I have the latest version of the script i was using it the other night with the The ally set  which is iRay only & I had to redo all the cut outs for the windows transpancy maps manually after i applied the script if you have the model set and you can try it yourself
    okay I just went and looked at my project its not trans maps i had to replace the glass textures in the set . because the windows shaders came out blank after i used the conversion script.  thats was what I had to re due.
    aaah, yeah, if you have 'proper' refraction based glass, that becomes a problem.
    Thankfully, in terms of scale, windows are usually not a hard subgroup to manage. One of the problems with a conversion is that you might want to use glass based on UberSurface, UberSurface2, AoA SSS, or some other thing (I vaguely remember at least one shader specially just for glass)
    Yes that is what I was using before you guys put out that useful conversion script.  I was using Omifreaker Uber shader pak and was using the simple shader conversion.. this script works great just some things still need a little tweaking not as much though as with out it .. its very helpful for those Iray only sets. especially other wise I would have had to remapped the whole thing
  • DaWaterRatDaWaterRat Posts: 2,885
    Well, I'm just planning a new series of images, so other than playing with the new light shaders, I haven't worked with Reflective Radiance much, but I fully intend to for this series.  (It just needs a lot of planning and prep-work, since it's a Sorte deck for 7th Sea.)
    I've played with it a bit, though, and I'm quite impressed with it. :)  Certainly worth the money.
    Hey great! Thanks for stopping by. If you feel inspired post a render or link when you have some results.
  • khorneV2khorneV2 Posts: 151
    RRE3 test
    Sharpen postwork only
    UE2 dome + USoftLight Kit + AOA lights
    PWeffects
    1000 x 823 - 168K
    Cool Effect. There is a nice glow on the face and body from the armor.
    khorneV2 said:
    RRE3 test
    PWeffects
    yes I see. It really does make sense to do these in 3DL. Let me know if you create any animations using Reflective Radiance. Would love to see that.
