How to load custom icon for Carrara plugin inside MCSketch?
I am unable to load custom icon/graphic for the plugin in MCSketch.
Please advise.
  • In MCSketch choose Edit > New Resource then select UImg from the list.  As well as the drawing tools you can paste images and a mask in from the clipboard from another image editor using the MCSketch top menu and Edit > Paste.
    If you add a TMFImagePart to your UI you can set the Image ID to display it.
    If your plugin is a primitive the SDK Flat example will demonstrate how to implement it.  If the UImg has the same resource ID as the plugin it will be associated with it.
  • Samuel S.Samuel S. Posts: 329
    Much Thanks; it worked for me!
