How to load custom icon for Carrara plugin inside MCSketch?
Samuel S.
I am unable to load custom icon/graphic for the plugin in MCSketch.
Please advise.
Please advise.
In MCSketch choose Edit > New Resource then select UImg from the list. As well as the drawing tools you can paste images and a mask in from the clipboard from another image editor using the MCSketch top menu and Edit > Paste.
If you add a TMFImagePart to your UI you can set the Image ID to display it.
If your plugin is a primitive the SDK Flat example will demonstrate how to implement it. If the UImg has the same resource ID as the plugin it will be associated with it.
Much Thanks; it worked for me!
