Lost In A Labyrinth - Question
Ati
Does "Lost In A Labyrinth" http://www.daz3d.com/lost-in-a-labyrinth have separate walls so I can build my own labyrinth? Or is it a fixed labyrinth that I cannot change?
Thanks! :)
Post edited by Ati on
I loaded it and it appears to be a single set with no individual walls.
ETA. The ceiling and grond are seperate, though
Thanks!
It looks nice, but it may not be what I'm looking for then.
Maybe this would work better for you: http://www.daz3d.com/merlin-s-labyrinth-construction-kit
Thanks for the tip. I had a couple of alternatives in mind, this was not one of them. But it does look promising. I'll take a closer look when things quiet down a bit at home.
It's very good, be sure to check out the bundle. This one is also very useful: http://www.daz3d.com/mazedness-for-daz-studio
I ended up getting Charlie's suggestion, it has space for nice camera angles as well.
Ati- Looks like you found an answer. You can create your own labyrinth with this set too: Mazedness. You can start from the small maze and load individual walls to grow it to the size and configuration you need.
