Lost In A Labyrinth - Question
AtiAti Posts: 9,208
edited March 2017 in The Commons
Does "Lost In A Labyrinth" http://www.daz3d.com/lost-in-a-labyrinth have separate walls so I can build my own labyrinth? Or is it a fixed labyrinth that I cannot change?
Thanks! :)
Post edited by Ati on
  • Charlie JudgeCharlie Judge Posts: 13,629
    edited March 2017
    I loaded it and it appears to be a single set with no individual walls.
    ETA. The ceiling and grond are seperate, though
    Post edited by Charlie Judge on
  • AtiAti Posts: 9,208
    Thanks!
    It looks nice, but it may not be what I'm looking for then.
    Maybe this would work better for you: http://www.daz3d.com/merlin-s-labyrinth-construction-kit
    Thanks for the tip. I had a couple of alternatives in mind, this was not one of them. But it does look promising. I'll take a closer look when things quiet down a bit at home.
  • riftwitchriftwitch Posts: 1,439
    It's very good, be sure to check out the bundle. This one is also very useful: http://www.daz3d.com/mazedness-for-daz-studio
    edited March 2017
    I ended up getting Charlie's suggestion, it has space for nice camera angles as well.
  • MarshianMarshian Posts: 1,465
    edited March 2017
    Ati- Looks like you found an answer. You can create your own labyrinth with this set too: Mazedness. You can start from the small maze and load individual walls to grow it to the size and configuration you need.
    849 x 412 - 534K
    Post edited by Marshian on
