Having a big problem with 4.9.3.166
AllenArtAllenArt Posts: 7,175
I'm making these mixed drinks models and you can see in the image I'm having a big problem that I've never had before in previous versions of Studio. So long as I keep the models (made into grouped sets with separate parented props parented to the drinking glass) in the same place and orientation as they the are when imported, they render ok. As soon as I translate or rotate them, I get what's in the image. This isn't my first time modeling a glass with liquid in it for DS either so I know what I'm doing ;). The liquid inside the glass is made FROM the inside of the glass and the mesh of the liquid is touching the inside of the mesh of the glass.
Has anything changed in this version that would cause something like this? I'm at a total loss and I must say this is extremely disappointing as I make freebies for DS semi-regularly. Any help or insight will be greatly appreciated.
Laurie
    For reference, the above are "supposed" to look like the images below (which had not been translated or rotated before rendering).
    1000 x 1000 - 608K
    1000 x 1000 - 623K
    1000 x 1000 - 573K
  • LinwellyLinwelly Posts: 6,070
    I have no experience with modelling so I might not be able to give any useful information,
    one question would be if you render in 3delight or Iray and if there is anthing special about the shaders you used ( different from what you used before). My first impression is that the mesh is interacting with each other, probably with the dispacement in the surface shader?
  • SzarkSzark Posts: 10,634
    if you are rendering in Iray then Iray likes the liquid mesh to overlap the glass mesh so they intersect.
    edited March 2017
    And when I do that (tried that already) I get weird shadowing. I just don't know what to do :( Something's changed in the Iray materials between the last version and this version.
    Laurie
    Post edited by AllenArt on
  • RGcincyRGcincy Posts: 2,862
    There was a recent problem with "On the Shore" rendering one shader black in .166. The PA fixed it and said this:
    "In this updates fixes the problem with the white and black spots in the DS 4.9.3.166. The shader mixer in new version DS 4.9.3.166 became more accurately refers to the maps of the alpha channel, so they should only be connected through the float. In this update, this problem is solved."
    Have no idea whether that change impacts you or not but is a difference in at lesat one shader property from the previus DS version.
  • 3WC3WC Posts: 1,147
    What are you seeing exactly?  The only problem I notice is with the milky drink, and some funny rectangles at the bottom of the chocolatey drink.  The other two look ok.
  • Digital Lite DesignDigital Lite Design Posts: 728
    edited March 2017
    When I made my set, the liquid inside intersected the glass about 1/4 between inner and outer.   I don't get weird shadowing.  The concepts is that if they don't intersect, you will get the weirdness and shadowing between the meshes.  Here is a render of my glass in .166.  It's grainey.  But you get the idea.  :)
    Laurie
    733 x 948 - 147K
    700 x 910 - 844K
    Post edited by Digital Lite Design on
  • FistyFisty Posts: 3,416
    And I do the opposite, leave a very small gap between the glass and the liquid.  Then again, I haven't "upgraded" to 4.9.3.166 yet.  Someone want to try my potion bottles and see if they have a problem?  They were a weekly freebie, most people should have them.  http://www.daz3d.com/perfect-potions
    edited March 2017
    Well, I tried with the liquid mesh sitting on the glass mesh and with the liquid mesh intersecting. I get the weird "hole" artifacts with the liquid mesh sitting on the glass mesh if I do any translations or rotations and dark shadowing on the glass and liquid when I intersect the liquid and glass a little bit. I get the worst shadowing on the SSS liquid shaders (milkshake, frozen pina colada, etc.) and less on clear liquids or liquids that have some refraction (vodka cranberry and tequila sunrise). I'm going to box everything up and send it over to my desktop and try rendering there to see if I have maybe a corrupted installation of Studio here on the laptop. I think I also have an early beta version still installed there as well I can test it in to see if it does it there.
    If it's a problem with an alpha, then the uber shader itself needs fixed so it only connects thru "float" as I'm only using the uber shader.
    Folks familiar with my freebies know I've made at least two glass props with liquid in them and I had no such problems with those ;). One was made with 4.8 and the other with the previous version of 4.9. That's why this problem has me so stumped. It SHOULD be working. LOL.
    Laurie
    600 x 600 - 53K
    600 x 600 - 415K
    edited March 2017
    This is with the liquid intersecting. Hopefully you can see the dark banding on the two outside glasses (choc shake and pina colada) and less on the two in the center (but still there on the tequila sunrise). Doesn't matter if the glass is straight refractive or glossy refraction or what the IOR is or whether or not it's clear or dispersive. Ugh. Maddening.
    Laurie
    1200 x 1200 - 726K
    Ok, this is pretty much what I want. Not sure what I did, but I'm afraid to move anything. LOL
    Laurie
    1200 x 1200 - 896K
  • barbultbarbult Posts: 26,546
    edited March 2017
    Here is a render of the potions and also the AllenArt drinking glass. I thought the drinking glass bubbles were supposed to be in the liquid, but they seem to be down in the bottom of the glass??? I don't see any bubbles in the orange liquid. It doesn't look like the image posted above. This was rendered with DS 4.9.3.166 just a few minutes ago.
    2000 x 1500 - 609K
    Post edited by barbult on
    Thanks Barbult
  • macleanmaclean Posts: 2,438
    I do the same as Fisty - I leave a tiny space between the glass and liquid. See http://www.daz3d.com/everyday-drinks for more images.
    1000 x 1300 - 394K
    edited March 2017
    The bubbles were a separate prop that I decided to let ppl use if they wanted because they were so poly heavy ;). It's probably there in your props with the glass and you just missed it :). There are actually bubbles IN the glass as well....looking at most of the drinking glasses that I have, 9 out of 10 have bubbles in the glass...heh.
    Laurie
    edited March 2017
    For whatever reason that wasn't working out for me and I'm not sure why. Intersecting the glass looked better but I had to make it bigger than just a smidgeon or I got strange effects like the very first image. I think next time I go down this avenue I'll make thinner-walled drinking glasses ;). Might make a difference tho I haven't tested it yet.
    Beautiful stuff you made btw :).
    Laurie
    edited March 2017
    Laurie
    Aha! Yup, there it is. I guess the thing that confused me is that there is a "bubbles" surface in the AADG_DringkingGlass. I didn't go looking further, because I thought that must be the bubbles in the beverage. Well, in my defense, it was almost 4 am when I set up that render. wink I wasn't in the clearest mind, but I wanted to support Fisty's request for a potions render. I think all three products in this render look great: potions, drinking glass (with bubbles), and everyday drink.
    2000 x 1500 - 650K
    I discovered with the first couple of models I made that the glass thickness can be crucial. I wasn't getting the effect I wanted, so I went back and made the glasses thinner and they looked a lot better.
    It's difficult to say exactly how thick they should be. Depends on the modelling program, etc, but it's definitely a really important factor in the final look. I'd go for as thin and as near to real-life glasses as as you can.
    edited March 2017
    Actually, I did model the glass over an image of a real glass, so the walls really are that thick. I think tho that thinner glass would be better - at least look a bit more realistic when rendered. I used Wings3D to model most things, mostly out of habit because I know it the best and therefore it's the fastest for me. I just started using version 2.1.5 and I modeled all the above in the new version, so I'm still not sure if it's not partly the mesh, but I don't see any reason why the resulting mesh should be different than with previous versions. But one never knows :).
    Laurie
  • hphoenixhphoenix Posts: 1,335
    Also remember that the TYPE of glass you are trying to emulate is important in relation to it's thickness......the IOR varies from Flint Glass to Crystal to Pyrex to etc., etc.  So different density glass will require different thickness to render similarly.
    edited March 2017
    Laurie, the milkshakes look wonderful. I added them to my potion shelf scene for a quick try. I hesitate to ask, because it sounds so greedy, but I loved those bendy straws in your earlier previews. Will those show up in a future freebie sometime?
    Interestingly, I rendered this one with spectral rendering, and the yellow potion in the round middle jar turned brown.
    2000 x 1500 - 761K
    Those will likely end up in the mixed drink addon for the milkshakes. When, I don't know at the moment ;). I need to redo them and see if I can't weight map them so the bendy part actually works. Morphs didn't work so well. Looked great at 0 and 100 but not so great at anything in between. LOL.
    Laurie
    Laurie
    Great! I'll watch for them. I love your stuff. It is as professional as stuff in the store.
    edited March 2017
    Laurie
    I finished the new straw and made it straight. Hope I learn how to weight map really quickly. LOL
    Laurie
    I can do it for ya if you can't figure it out Laurie.
    Barbult - no idea.
    edited March 2017
    Barbult - no idea.
    Aw, that so nice of ya Fisty, but I gotta learn it sometime :P. LOL I'm not SO dense that I can't figure it out ;). I think. I hope. Heh.
    Laurie
