Electronic Tools - Iray only?
Stryder87
in The Commons
This is a very cool little 'out of the blue' set. Something you never thought you needed until you saw it.
My question... is it Iray only? The promo is done in Iray, but it actually doesn't mention which shaders it comes with, not even Iray.
http://www.daz3d.com/electronics-tools
I got this for free as an MM Bonus Buyer, but yes, all of the shaders are IRay.
Quite a few of the materials are texture based, so with some fiddling these could be manipulated for 3DL use, but there is a fair bit of shiny metal in the set, which will need some work to look as good if not using IRay.
Below is a quick 3DL render with no shader adjustment.
I just checked it & the shaders are Iray only but it does render in 3DL without doing anything special - If you are good with 3DL & make changes I am sure it would look perfect
edit: Havos got there first but seems like we agree :)
There's a 'convert Iray to 3dl' script in freebies section, probably works on this.
http://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script
Thanks all.
