Electronic Tools - Iray only?
This is a very cool little 'out of the blue' set.  Something you never thought you needed until you saw it.  laugh
My question... is it Iray only?  The promo is done in Iray, but it actually doesn't mention which shaders it comes with, not even Iray.
http://www.daz3d.com/electronics-tools
  • HavosHavos Posts: 5,703
    I got this for free as an MM Bonus Buyer, but yes, all of the shaders are IRay.
    Quite a few of the materials are texture based, so with some fiddling these could be manipulated for 3DL use, but there is a fair bit of shiny metal in the set, which will need some work to look as good if not using IRay.
    Below is a quick 3DL render with no shader adjustment.
    1024 x 1024 - 224K
  • TottallouTottallou Posts: 555
    edited March 2017
    I just checked it & the shaders are Iray only but it does render in 3DL without doing anything special - If you are good with 3DL & make changes I am sure it would look perfect
    edit: Havos got there first but seems like we agree :)
    800 x 1000 - 216K
    Post edited by Tottallou on
  • Oso3DOso3D Posts: 15,116
    edited March 2017
    There's a 'convert Iray to 3dl' script in freebies section, probably works on this.
    http://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script
    Post edited by Oso3D on
  • Stryder87Stryder87 Posts: 899
    Thanks all.
