Customize navigation?
Hello.
Is it possible to customize viewport navigation in Hexagon? I'm accustomed to Maya's and the swap of mouse buttons in Hexagon confuses me a lot.
Hello.
Yes you can change the shortcut keys, look in Edit-Shortcut Editor and select the View option. Not sure about the mouse button option, I've set Hex so each view has a key on the key pad.
Thank you for your reply, Wee Dangerous John. Unfortunately, there doesn't appear to be any way of changing scene navigation controls. Even via shortcuts window.
Here's a screen grab of the View section of the Shortcut Editor, all you have to do is click on the button you want to change and choose a key which has not already been allocated.
The OP will be referring to the "Alt+ mouse button" for screen navigation. In Maya "Alt+MMB" = Pan. "Alt + RMB" = Zoom. In Hexagon that is reversed.
Yes, that's exactly what I need, but the Shortcut Editor doesn't allow any customization of mouse navigation. :(
Does DAZ3D have any plans of implementing this in one of the next possible Hexagon updates perhaps?
