Lost Content Library
larrygilmanlarrygilman Posts: 130
My Content Library seems to have drifed away. Sounds strange I know, but I noticed that as I was adding items that the space between the left edge of the frame and the left edge of the List pane kept getting larger and larger, until the left edge went past the right edge. I have been installing quite a items of new and older DAZ / Poser.
I was just looking at another computer that I have DAZ 4.5 installed on and noticed that there are two back to back arrow heads. No matter how much I move the the window panes, up down or left right. That second from the top arrow head is not showing.
The first system is a high end laptop, the second system is a medium high end gaming PC. Both have Win 7 Pro.
Any ideas what happened and / or how to fix with out starting over???
Thanks in advance of ANY help.
    You could try changing to another Layout, closing the Content Library if you can see it, then changing back to your original Layout, and going to Window > Tabs > Content Library to load it again.
  • larrygilmanlarrygilman Posts: 130
    edited January 2013
    Thank you very much, I have my Content library back now.
    Post edited by larrygilman on
