DazStudio_3.5.1.56_Win64 Smart Content is missing after install.
edited January 2013 in Daz Studio Discussion
Installed DAZStudio_4.5.1.56_Win64, now the smart content is missing. How do I fix this?
I am running Windows 8 pro.
Post edited by janetweber_332d002bac on
  • fixmypcmikefixmypcmike Posts: 19,729
    Did you install Genesis Starter Essentials?
    If you go to the Content Library tab, Is there anything in Categories, even just the Default category?
  • edited December 1969
    There are no categories or products period. See the attached file.
    488 x 984 - 45K
    Either CMS isn't running or it's being blocked from communicating with DS, I'm not sure how you access it in WIn8, but in Win7 it's Start Menu > Programs > DAZ 3D > DAZ Content Management Service > Start CMS. Then restart DS and see if it's working.
  • Richard HaseltineRichard Haseltine Posts: 111,675
    In Windows 8 you'd just type "CMS" while viewing the start page (there isn't a text box anymore, but search still works as if there was and the cursor was in it).
    That does not work..
  • SzarkSzark Posts: 10,634
    Janet you didn't answer Mike question
  • edited January 2013
    I did install Genisis Essentials....
    LOL I see you found the question. :)
    When you first opened Daz Studio do you get a Metadata loading window asking to import the Metadata.......if not you will need to run the metadata config window.
    Smart Content Pane > Options box (top right small striped box) > Content DB Maintenance > Reimport Metadata
    That did not work either. Do you have any more ideas?
    Instead of "CMS" search for "Content Management Service"
    That did not work either. I think the Content Management Service is not being installed on windows 8. I looked but it is not listed in services. I there a way to fix this?
    I got the content manager working. Had to completely uninstall it and then reinstall DAZ Studio. Then I had to re-import the metadata.
