Has anyone bought Leah for V5
Pendraia
Has anyone bought Leah for V5?
http://www.daz3d.com/leah-for-v5
If so could you please post a render of what she looks like from the side?
I think she may be perfect for a series of renders that I want to do but need to see a side profile first.
Thanks
Pen
Super-quick render using default light, default (non-HSS) shaders, and pausing only to put hair in ponytail and throw on a bikini ;-).
HTH (^_^)n
(cilck for somewhat larger)
Slightly more time spent on lighting, and to show off her bod.
Thank you...that nose is just what I want but couldn't tell for sure from the promos.
Here's a close up of the face same mats as the other poster used...lighting is from Aiden M5.
Oops forgot to include image. :red: See next post.
Here is a close up of the side profile of the head only.
Is she V5 UV?
Yes, surface tab shows it's set to the V5 uv set.
Thanks the nose is exactly what I need...
She looks really nice. what are your impressions from using her? I've spent so much on this stuff over the past few months that I'm hesitant to spend more, but I just might have to on this one.
Hello Pixel8ted and or anyone else who has brought this so far.
I just bought Leah, but noticed that on a closeup render of the face, the lips show pits kind of like strawberry.
Could you check your and see if you have the same issue?
It's in the texture before the render and shows more so after rendering.
Yeah, I notice that also when doing a close up render. I didn't really catch that on the distant renders. Looking at the face textures, it looks like jpg compression artifacts. I'm deciding if I want to touch up the lips with Photoshop's healing brush or do a return of the texture. I'm leaning towards keeping her but seems a bit of an annoyance to have to do touch up all of the lip makeups. Sigh, I guess we should have examined that first close up image on the sale page. If you really look, you can see the spots on the lips in that first render shot. Then again, who is expecting that...
You pretty much echoed what I was thinking!
Should I try fixing all the textures in photoshop or just return, because I liked the character shape.
I never seen anything like that on any of the other textures and as you said was not expecting it..
Then when I did a render, made me look closer at it.
