Need help with skin, lights and rendering results.
edited January 2013 in New Users
Hello,
New Daz3d user here, I've been learning by playing with the software for the last week and it is too much fun!!!
This forum has been a big help.
I need help with improving rendering results for skin. I am trying to render portraits and interested in semi-lifelike skin results.
Something like the fighters renders I attached. (not mine)
However, I can't for the life of me understand what it is exactly that is affecting how the skin renders...in some renders I've seen online the skin looks like video game character skin, in others it looks like a doll skin, in others it looks like real life skin, and anything in between.
I'm looking for results similar to the fighter renders i attached or even more towards real life skin...
For example, I managed to render this woman portrait I attached, using uberenvironment and the 3 lights setting that was recommended here for portraits.
The problem is that in this render, her face and hand are pretty close to the result I'm trying to achieve, but the rest of her torso looks awful in comparison. It's yellowish and doesn't look real at all, while the hand and face look much more real and have a nice skin color to them.
Is it the lighting? is it something else ? what is causing this? How do I affect the way skin renders?
I'm trying to experiment with stuff until I get the right results but I'm really confused and want to know what I'm doing, instead of just randomly trying things and wasting time. So this is my main struggle right now.
Additionally I have 2 more unrelated questions:
1. Can I use 2 different skin textures on one figure? Some "characters" I bought on renderosity come with textures that affect the way their face looks...without the texture the face looks different than "advertised" for some reason. However, sometimes I want to keep the face but don't like the texture on the rest of the body.....can I replace it with another one but keep the face with the appropriate texture?
2. When manually posing figures, I often struggle with aligning whatever limbs are supposed to be touching the "floor" to the actual floor line.
Can the "floor" grid be set to be non passable, meaning that the figure or any of its limbs cannot dive under the floor ? if not, is there another solution for making it easier?
That's all for now. Sorry this was a bit long....Thanks a lot to anyone willing to help!!! :)
Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
Post edited by teldil_d916c75975 on
    I find the front view is the most useful in making sure feet are at the right level (you can see the ground planar level as a straight line). There is no ground collision mechanic.
  • scorpioscorpio Posts: 8,534
    You can't really use two different characters skin a the same time the seams won't match up nor will the skin tone etc.
    The things that effect skin appearence are lighting and the surface settings.
    Here is a basic guide to the surface settings in DS
    http://homepage.eircom.net/~neilvpose/ds-settings.htm
    Its for an older version of DS but is still relevant.
    A lot of the getting it how you want to look is trial and error.
    There are several threads about the forum discussing lighting and surfaces especially skin its worth while reading them.
  • NeilV_1NeilV_1 Posts: 442
    edited January 2013
    In this months new users contest WIP thread I also give some basic settings and advice on setting up skin for rendering in DS http://www.daz3d.com/forums/viewreply/210689/ which you may want to take a look at
    Post edited by NeilV_1 on
  • JaderailJaderail Posts: 0
    Well not fully true, you can use two different Skin textures if the textures are both for the same Figure. Example you could mix two V4 skins on a figure by loading the different textures onto the proper areas in the Surfaces tab. But as stated the Tones might not match from one texture to the next. But it can be done this way.
    Actually you can use the limbs from a M4 texture and the torso from a V4 texture as long as you set the UV correctly. I've done it in order to create a certain look, but I wasn't going for 'realism'.
    I keep for getting that DS4.5 added that feature. I'll need to remember that tip for the future.
    I was doing it before 4.5 UV swopping came in with Genesis and DS4.
  • mark128mark128 Posts: 1,033
    I would guess the yellowish areas you are seeing on the torso are specular highlights.
    Select the figure, go to the surfaces tab, expand the figure and select the skin torso settings.
    First I would check the textured used in the diffuse channel to make sure the yellowish color is not on the texture map. I think this is unlikely, but if it is, then the only way to remove it is to edit the texture map in a photo editing program like photo shop or gimp(free).
    Assuming this is not in diffuse skin texture, I suspect the yellowish spots are specular highlights. The tutorial linked to by scorpio64dragon does a good job of explaining the interaction of glossiness and specular strength. Try turning the specular strength to 0 on the skin torso and re-render the image and see if the yellowish goes away. If it does then you can adjust the specular strength down and change the color of the specular highlights till you get the look you want. You probably will want to make similar changes on the other skin areas too. I suspect the reason you are not getting the same thing on the face and hands has to do with the angle of the light and the shape of the face and hands.
    The other thing some vendors do is add a little bit of color in the ambient channel. This of course is not real. Human skin does not glow in the dark. But I have seen skins with ambient strength set to 100% and a color like 20,0,0, which is putting out a small amount of red light, to give the skin some "pinkish glow." I have also seen skin textures that setup a stronger red or pinkish ambient color, but have the strength at 5 or 10%. You can affect the color of your skin areas this way too, but this effect will vary with the lighting of the skin.
    I have a few skin textures from figures I bought at Renderosity, and they do not render very well in DS. I have to fiddle around with the skin surface settings a lot to get any kind of acceptable render in DS. I suspect that the presets they include are for Poser, and Poser handles lighting differently than DS, so Poser values do not render very well in DS. I think DAZ makes vendors that sell products through the DAZ store create different presets for DS and Poser in their products.
    I don't think there is any magic for this. After posing the figure, you just need to get down low with the camera and adjust the hight. As long as you have it close, it will look fine when you render it.
