DAZ Dimension Lights 1 and 2
2»
  • ArtiniArtini Posts: 10,477
    edited January 2013
    These lights are great. Used Light set 01 from the DAZ Dimension Lights 1 without any changes.
    Click the image to see it enlarged.
    800 x 1024 - 305K
    Post edited by Artini on
    I have used the Render Settings depicted below.
    406 x 790 - 102K
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,310
    Beautiful image! I want to pick this set up when it's on sale again - missed getting it before.
  • SpitSpit Posts: 2,342
    Thanks for the info on the render settings shading rate vs UE peeps.
    Thanks for the comments. I like these lights, because of the moderated rendering times.
    The image above took around 15 minutes on the computer with the first generation i7 processor (2.8 GHz).
    I have used Pure Hair Lovely in the scene without any changes, except the material color
    http://www.daz3d.com/pure-hair-lovely
    I wonder how long rendering times will be with the different hairs.
    Rendering Settings are playing an important role on the speed of rendering
    and the quality of the resulting image, as already mentioned in this thread.
  • SamanthieSamanthie Posts: 308
    I picked up both light sets today. So far I can't get a render to complete, and ds stalls about 9 min in. I have downsized the render just to see if I could get any output at all with same results. The spot render tool will not work either. What I also see is in the render window are squiggly lines of red and blue instead of the usual black screen. Working on an HP notebook, windows 7, 64bit. Can't find a readme or other documentation. Any help is appreciated. Thanks.
  • fixmypcmikefixmypcmike Posts: 19,707
    How much RAM do you have, and are you using 32-bit or 64-bit DS4?
    system memory 3gb
    microprocessor:celeron dual-core cpu T3500 2.1ghz
    Graphics device:mobile intel 4 series express chipset
    I'm using DS4 64 bit
    Maybe my laptop was just overworked last night. I was able to get a render this morning in 3delight, default settings (no squiggly lines and no stalls). It took about 50 minutes. I like the light sets, did not fiddle with anything. I used DDL#12
    v4
    Curator Aquarum
    Bunny Dazed
    932 x 570 - 362K
  • SlimerJSpudSlimerJSpud Posts: 1,456
    edited August 2014
    Kerya said:
    DS4.5 only - they are in DUF format ... Sorry!
    For the DAZ Dimension Lights 1 it says it comes with "1 DAZ Studio Legacy Installer " which installs .daz files, not .duf files. They did not work in DS3. It says they were created for a newer version of DS. I just got these based on them having a Legacy Installer. Everything else I have bought that came with a Legacy installer worked in DS3.
    Edit: Support ticket opened. Let's see what happens. *heavy sigh* :down:
    Post edited by SlimerJSpud on
    The Legacy installer is for DS4.0. The change over to DUF began with the release of DS4.5.
    This is what bothers me. Take a look at these two products. They both say exactly the same thing, that they have a Daz Studio Legacy installer, and they both say they work in Daz Studio, and Daz Studio 4.6. One of them works in DS3, one does not, but the descriptions are identical on this point. Product descriptions should be specific about what versions they support, IMO.
    http://www.daz3d.com/atmospheric-effects-cameras-for-daz-studio (works in DS3)
    http://www.daz3d.com/daz-dimension-lights-1 (does not work in DS3)
