Look at my Hair: official thread [Commercial] RELEASED!
Adding to Cart…
Looks like an angry tribble that's just come out of the washing machine...
Hello Richard, about exporting to .OBJ, what you can do is to decrease the geometry complexity (it's a slider), which will decimate the mesh and help reduce the polygon count. But the exported .OBJ, while inheriting groups from the underlying model, is not auto-conformed automatically.
Thanks for the info. But the obj can be conformed using the same methods used to conform clothing to Genesis so it has that built in scaling as the model is deformed, correct?
Correct. There is no difference between an obj output from LAMH and the OBJ from a hr2 hair.
Kendall
After you finalize the scene you should be able to change Genesis' resolution back to high.
Yeah, that's what I thought, too. However, I've tried every setting I can find and the resolution stays firmly low (short of converting it to SubD which can mess up texture mapping and conforming clothing). So, the only solution was for me to duplicate the figure. If there's something I am missing for how to get it back to high resolution, I'm all ears.
Thanks.
Alessandro_AM.....just about to purchase LAMH, but want to make sure my laptop has the required specs:
Gateway NV59
Intel Core i3 CPU [email protected]
4G memory installed, planning on adding another 4G
64 bit operating system
AMD Radeon HD 6500M/5600/5700 series
HD 5650 Graphics 1G
I had severe crashing issues with the Garibaldi plugin, kept freezing during the clumping and tweaking stages, and would crash Daz constantly. Prefer LAMH because I can export as OBJ and render in Reality. Can't afford a new laptop for quite some time, so this will have to do. Not sure if switching the graphics card is possible or feasible. Please advise......Thanks in advance.....:-)
Thanks.
There should be no problem AFTER finalizing your LAMH hair setting the resolution back up to high. If, for now, you have to re-edit your LAMH hair, the resolution will be made low again. We recommend that until we get the next update out, that you only set the resoultion back to High right before rendering.
Kendall
Your specs look fine. We've had some problems with Intel Gfx GPU's that have been resolved after upgrading the Gfx Drivers. There are one or 2 revisions of the Catalyst drivers that cause problems, but as long as you are upto date on the drivers for your OpenGL layer, your system should do fine.
Kendall
As posted on this thread: http://www.daz3d.com/forums/discussion/14662/
Wolf by AM preset if available for free at LAMH Presets page.
it is beautiful
Wow!! Nice looking wolf there, Alex!
One issue with the animals you made was the fur, but now with LAMH, they'll have a renaissance.
Thanks.
Absolutely, now those critters look happier with their new fur coat, isn't?
Aroooooooooooooooooooooooooooooooow
Oh.. I wish I had the Wolf now... argh, darn beginning of the month bills. :)
Really enjoying this program, the mileage I am getting out of the Bear and Big Cats now is amazing!
Richard, I did this for you. I hope you like it...
Another render with a short style for 'Val'.
Kendall
Thanks Kendall!
THANKS Alex. WOOF WOOF
A second short hair style for Val.
Can 3 gigs of ram, an Intel Core 2 Duo 2.20 ghz E4500 CPU and an ATI Radeon HD 2400 handle it?
This is the best female hair style I've seen so far. Very beautiful!
I am playing around and have much crashes direcly after rendering. Could be after changing the color of hair?
Hmm...cannot say what I have done if it crashes or not... This time it works. Could also be there are haevy much textures in the scene at all...
This is several times larger than one of the test platforms I use to test LAMH on -- 1.5G RAM, AMD Turion Processor, AMD Radeon HD3200. So you should be just fine :-)
Kendall
Do the crashes happen after the render completes? If so, then the issue may be 3Delight related. What are the specs of the machine?
Kendall
Yes, I think the render was ready but then before I can save Studio crashed.
I have Windows7 64bit
16gb ram
Intel i7 3.5GHz
AMD Radeon HD 6800
It is a little bit strange... now I have more in the scene (background and props and lights with shadows) and it didnt crash anymore....
Dont know what it was....
Hey Guys,
Can you say when the Update is due for release.???
I am awaiting the update before I purchase so a ballpark idea would be great.
Cheers,
S.K.
Hi Juju, be sure that LAMH is always open when you render, otherwise you might end up in a render crash during or after it has completed.
I suppose it's a 32bit system, so yes, technically you match the specifications, but i'd say that you are limited to creating a maximum of 2 million curves (I experimented on a similar system that I have at home).
