Figure files: What do INJ and REM mean
When I'm starting with a new character I come to choose the maps for the body and skin.
Shall I load both the "!character INJ" and the !character REM" file? What are each of them for and what does the green PLUS and the red MINUS in the window mean?
The Inject file injects the morphs needed to create that particular character, with the parameter dials set to the correct setting
THe remove file removes these settings, if you decided that the character is not the one that you want to use.
Oops, that is good to know, that REM means "remove"! ;-)
But there's still the question "What do a green + and a red - in the preview window mean?"
What Preview window? Do you mean the Content Library or Smart Content panes?
If so, the '+' sign is another way of saying INJect, and the '-' sign is another way of saying REMove.
Is that what you mean, if not please post an image so that we can help you.
They do try to make it more obvious with the + and - signs.
So + for INJect or add and - for REMove
OK snap again Jimmy, cos I tried to make my post pretty.
That's what you get for showing off. :)
I thought about that too, I must say yours is much prettier than mine, well done Pam.
