Figure files: What do INJ and REM mean
WolpiWolpi Posts: 323
When I'm starting with a new character I come to choose the maps for the body and skin.
Shall I load both the "!character INJ" and the !character REM" file? What are each of them for and what does the green PLUS and the red MINUS in the window mean?
    The Inject file injects the morphs needed to create that particular character, with the parameter dials set to the correct setting
    THe remove file removes these settings, if you decided that the character is not the one that you want to use.
  • WolpiWolpi Posts: 323
    edited January 2013
    Oops, that is good to know, that REM means "remove"! ;-)
    But there's still the question "What do a green + and a red - in the preview window mean?"
    Post edited by Wolpi on
    What Preview window? Do you mean the Content Library or Smart Content panes?
    If so, the '+' sign is another way of saying INJect, and the '-' sign is another way of saying REMove.
    Is that what you mean, if not please post an image so that we can help you.
    edited January 2013
    They do try to make it more obvious with the + and - signs.
    So + for INJect or add and - for REMove
    OK snap again Jimmy, cos I tried to make my post pretty.
    Post edited by Chohole on
  • SzarkSzark Posts: 10,634
    That's what you get for showing off. :)
    I thought about that too, I must say yours is much prettier than mine, well done Pam.
