Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Helping Users have Fun and Enjoy 3D is what it's all about for me. Enjoy yourself and happy Rendering.
Files with the *.dmc extension are for use with the Mimic plugin. I thnk those are the sound files. I'm just starting to animate, so I don't know if they will work with any of the other animation apps or not.
Ok I am doing well just wondering about the V4 ++ morphs a lot of my past characters need them I have tried to install them the way you said above but they do not seem to show?
if they are in the were do I assess them to add some of my other characters
do I have to have the original normal V4 installed to use or will my older characters work on the genesis?
sorry it is all a bit confusing ...what will work and what will not :(
I really appreciate the support you are giving me
virtual hug coming your way XX
Love Janice
Also there is a model I love to use but is not Genesis can you put requests in for them to be or does it have to be the owner of the character that has to do it
I know you have Mavka as a genesis but wondering if Cookie would?
Hi Jaderail
so all I have to do is purchase and add this product
http://www.daz3d.com/genesis-generation-x
and I can then use all characters that ask for A4/V4++ morphs?
I have this products
http://www.daz3d.com/v4-and-m4-shapes-for-genesis
so am I reading it right that if I have this I can just get the upgrade?
http://www.daz3d.com/genesis-generation-x-upgrade-from-gen4
some of my old characters need A4 and G4 morphs so how do I get them to work?
I have purchased this but I am asuming it will not be the same?
http://www.daz3d.com/gen-4-iconic-shapes-for-genesis
for example here is a character
A4, V4.2 Morphs++
or V4+++ with morphs for A4 and G4
Sorry for all the questions I am so frightened of spending more money than I need :)
Love Janice
I use only the Gen4 Iconic Shapes and the Legacy Morphs for Genesis. Those two sets will let you Build almost every old character you ever had. Of course you will have to build them by hand again.
oh ok thanks
Quote
"I use only the Gen4 Iconic Shapes and the Legacy Morphs for Genesis. Those two sets will let you Build almost every old character you ever had. Of course you will have to build them by hand again."
So if I had the Full GenX plugin from Daz3D
I would still not get this character to automatically pick up the morphs from the product ?
is that right?
she uses Victoria 4.2 Morphs ++ Aiko 4
http://www.renderosity.com/mod/bcs/frad-bambi/66080
if so can I just load them in all the original models and morphs like I have in my poser 8 and use them in the original way and not use the genesis for them?
Big hugs Janice
No it is not Automatic, You will need to learn how to use GenX to transfer the Morphs from the A4 Morphed figure to the Genesis Figure. That is why I just create my old figures by hand again. No extra Plugins needed and when I'm done I have a full 100% Genesis only figure that I made myself. Here is my M4 Jade character.... and my Hand made Genesis version of Jade... I have much better control and options using only the genesis stuff.
Wow he is fantastic!
Ok thank so much you have saved me money and helped me so much <3</p>
Love Janice
I just got and downloaded DAZ Studio Pro 4.5 from this site earlier today. Every time I try to click the DAZStudio_4.5.1.56_Win64.exe file to install the program, I get an error message that says "Installer payload initialization failed. This is likely due to an incomplete or corrupt download file." I have redownloaded the file 4 times and keep getting the same message. HELP!! Am I doing something wrong, or is there another place I can download the file from?
Thanks in advance,
Shawn
Daz 3D did go down a bit, but I'm thinking you Need to Clean you Cache. If a DL fails and you do not clean your Browser Cache your next DL will just Fail at the Same place. The Browser is thinking its a FULL down load and stops. Reset you Download after you clear your Browser Cache and try again.
thanks for this. I read your instructions (Jaderail) on the old DAZ forum, and you recommend unzipping first to a holding directory, then copy/merge to the runtime. But I usually unzip direct to the runtime directory and provided the unzip program has the "merge directories" option ticked, it should be ok, right?
I think the issue is that installed content only has Runtime as the top level directory. Underneath that are directories like Textures, Props etc. If "merge" isn't on, then each install will just create a new set of subfolders within Runtime and may even over write existing content. Is that right?
Yes you are correct, merge must be on or you can and will lose content that already was installed.
Link to the instructions mentioned would be appreciated, I have hundreds of older DAZ figures and content archived that I would like to install in DS 4.5
That was an older Tut and All Graphic, But if you tell me your OS and your Content Folder I'll gladly do a Short Tut for you.
Thanks Jaderail,
I am running win7 Ultimate 64 bit and my DS install is C:/ProgramFiles/DAZ 3D/DAZStudio4/Content
Not sure if the content folder was there to start or created by me attempting to install V4. There are the following folders in the Content folder; ReadMe's & Runtime, all the folders in the Runtime look like the old Poser file structure (Geometries, Libraries, textures) and all contain files that belong with blMilWoman_v4b
Ah well yes I see a problem right off, In Win7 you can not Have Content in the Programs folder. Win7 protects that area of the drive from all but install writes. You should have a Daz 3D folder in My Documents this is the full path.
C:Users/(Your Name)/Documents/Daz3D/Studio/My Library when Installing content with an EXE installer you need to point it to that path. The older installers have not been up dated and Point to the old content path. You should Delete that Folder and Re-Install to the My Library folder.
I now know how to help you with Zip files as well. I'll do you a tut tomorrow I'm not able to tonight because I have a early Appointment in the morning.
You are awesome !!!
I hope you get some compensation from DAZ for being so helpful on this forum.
I am starting to remember why I gave up on DS a couple of years back..... now my head hurts all over again:P
I followed your instructions but I can't get V4 to load and now the stock Genesis figure will not display properly, just get a stack of boxes piled up in a human shape.
Would I be better off uninstalling this mess and starting over with a custom install in a non protected location like D:/Daz
I'm sorry I'm still writing a tut for you but your Genesis thing is you have accidentally changed your settings in the Viewport. Look here and that will fix you right up. As for V4 Open the Content Library Tab and look in Poser Formats>My Library>Figures>Daz People that will hold your V4 figure. Look in Daz Studio Formats>My Library>People> and you will find most of the other content. V4 is an older model and Should be found there. Here is your Fix for the Boxes.
Thanks Jaderail,
I managed to get some things installed but had to put them in C:/Users/public/Documents/My Daz3D Library/Studio/My Library
I followed your instructions and the folder under my user account does not load anything, the folders are created but the contents are not???? gotta be a Winblows issue
That's not a standard path -- are you sure that's where the files are being installed and that's where DS is looking for them?
I'm with Mike I do not believe your content folders are set up properly. I also doubt if your Content Paths in DS4.5 are set up properly.
Could you go to Content Directory Manager and Expand your folders and post a screen shot? Here is mine on my Win7 .
Ok after a bit of searching I found the content manager, here is the mess I have created, you will likely be able to explain how to fix the error in the second screen shot by looking at the first.
G:/ is an external drive that I had backed up some files from my last attempt to use DS.
This should help. And yep it's a bit of a mess. I'm very tired, so if you need more info on this please ask.
In #4 by top listed I mean listed as BOTH the top in Daz Studio Formats and as Poser Formats. All folders that have any Daz Studio only content need to be listed in both.
I uninstalled everything, deleted all the folders that were not where they belonged, reinstalled DS in its default location.
Next I downloaded and installed DIM then downloaded a couple of the ready for download files and installed them......well guess where they end up c:/users/public/documents..... all over again. I found a tutorial on using DIM and it states you can change the install location but that option only allows me to confirm the files are going in the wrong place, the entry is greyed out and I can not access it to put the proper location in.
is there a way from inside DS to migrate these files to the proper location or does this require the old cut and paste drill that inevitably goes wrong some where mid stream?
The C:\Users\Public\Documents\My DAZ 3D Library is the Correct path.
you had one with extra folders Mine is in that path and only in that path. It is also the only path I have Mapped.
