No importer for the opening Genesis figure in DS 4
chriswongbizchriswongbiz Posts: 208
HI,
If I started DS 4, and the genesis figure is not showing, and there is a message, saying "No importer for the file format can be found", what is missing ( what file? I might have moved things around by mistake ) and how can I locate it to fix it again?
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 108,065
    Are you using DS4 or DS4.5? If 4.0, did you install the updated Genesis Starter Essentials?
  • chriswongbizchriswongbiz Posts: 208
    DS 4. Should I install it?
    I have installed Genesis Starter Essential 1.6, but is it supposed to be for DS 4.5, i am using DS 4, so is it not good for me?
  • JaderailJaderail Posts: 0
    No, DS4 does not read the NEW .duf format files that DS4.5 does.
  • fixmypcmikefixmypcmike Posts: 19,689
    The DS4.0 installer includes the content. For DS4.5 the content is a separate installer, and the DS4.5 content won't work in DS4.0. Either uninstall the Genesis Starter Essentials and reinstall DS4.0, or install DS4.5
