Edit items before the render?
I am a bit confused. Sometimes I load an item in DS, and it might be made up from a number of separate items.
I know I can edit by deleating one item, part, at a time..... but what if I want to delete everything in my DS screen and load, for example, a different setting?
How do I do that?
Thanks.
R
  • barbultbarbult Posts: 26,586
    edited January 2017
    I'm not sure I understand what you are after, but you can clear everything and start fresh with File>New. You can also select multiple items in the Scene pane by holding down the CTRL key. Then you can delete them all at once.
    Edit: It is File>New, not New Scene.
    Post edited by barbult on
  • BendinggrassBendinggrass Posts: 1,381
    barbult said:
    I'm not sure I understand what you are after, but you can clear everything and start fresh with File>New Scene. You can also select multiple items in the Scene pane by holding down the CTRL key. Then you can delete them all at once.
    Thank you, that is exactly what I needed to know. Yes, sometimes I want to clear everything.
    Very appreciated.
