ISO G3F holding Baby pose (Solved)
Charlie Judge
I'm looking for a G3F (or possibly G2F) pose holding a baby, or even holding up some other large object that I could use as a starting point Any suggestions?
Post edited by Charlie Judge on
This one I did a while back, it's not perfect but I'm sure you can use it as a starting off point. :)
Thanks Diva. It looks good. What figure(s) is it for?
I also hoped I'd be able to find one with the baby vertical, similar to the attached photo.
The figure is Gwennili but it should work for any G3F.
I don't have a vertical "baby on hip" pose, sorry. :(
Hivewire have a set for Dawn Dusk and Luna which will work on G2 with a bit of tweaking but they won't work with G3, its called - Family Poses for Dawn, Dusk and Baby Luna. There's not one the same as that you posted but a couple that have the baby upright.
I can probably make the pose, but the only baby I have is genesis 1 version baby.
If you feel like making it that would work at least as a start. Thanks
Charlie Judge what figure do you have for the baby??You want a G3F holding the baby on her hip or in front of her??
okay, that's what I knocked out based on your picture. Let me know if that is what you need, and you are welcome to have it.
I have both the Millenium Baby and the Genesis baby
SereneNight: That's great It should work fine. I would have liked G3F to be standing a bit staighter and not leaned back as much but I can probably adjust that and if not it will still work for my purposes. Thanks for all your efforts.
Okay, I'll post it to my freebie thread in a few minutes.
Got it and downloaded it. I played around with adjusting it a little bit and it will work great. Thanks ever so much
Charlie
Cool! Glad you liked it. It was interesting to pull out genesis babyand do something with him.
@Divamakeup I know I'm late to this event, but had to tell you your pose is a godsend for me. I came across this thread in a search-engine search after having worn myself out trying to find a commercial pose package that had that pose. I'm amazed that there isn't one, given that that is how parents the world over spend so much of their days with a newborn. I can't thank you enough!
You're welcome - I'm really glad you found it helpful! :D
