How do you change Eyes shader back to DAZDefault after you applied Iray?
My eyes are acting weirdly so i want to change the shader back to daz default. The cornea is daz default but for some reason the Eyereflection says it is Iray uber.
It's in the shader presets as !DS Default.
Though ... this is a bad idea. ;) I would suggest selecting Cornea, Eyereflection, and Tears, and click the Water Iray Shader (people say Water - Thin, but I prefer the regular one), and then set Cornea's Refraction Index to 1.36.
I also suggest, in Shaping tab, changing Eye - Cornea Bulge to 1.5 (you can turn off limits by hitting the small gear next to the Cornea Bulge header, hitting Parameter Settings, and unchecking Parameter Limits)
