I wasn't happy with my work-in-progress ... so I started a new one.
It shows a scene from the science-fiction novel "Blindsight" by Peter Watts. This image shows the moment when the aliens (called scramblers) swarm aboard the spacecraft "Theseus".
"Theseus", in the foreground, is assembled from bits and pieces of Stonemason's Modular Sci-Fi Kit 01 and from the incredibly useful Nurnies Greebles Parts and Pieces. The scramblers were modeled from primitives and spline objects. That evil-looking black thing in the background is called Rorschach, and it's also made from heavily-deformed and duplicated spline objects. It's lit by a single spotlight, targeted to light only Rorschach (which produces the bluish sparkle, from reflective highlights). Big Ben, the planet in the background, is a heavily tweaked version of the "Special FX/Lava" example that ships with Carrara.
The invading scramblers are placed using a surface replicator. There's actually a terrain object on top of the hull of the spacecraft, and the scramblers are distributed on top of that. The terrain object is set to invisible (handy pro tip: a surface used by a surface replicator doesn't need to be visible to work).
This is a close-to-final version of the image. The final version should include a couple of human figures on the hull -- Siri Keaton and Robert Cunningham, realizing too late that something has gone badly wrong. And I'll probably post-work it slightly to make the details stand out a bit more.
I like this belt and leggings much better for the Asia-inspired uniforms. The camouflage for the cylon/stormtroopers - is that a procedural or a texture map?
The camouflage is a digital-camo texture, that I made in Genetika. And her its used together with Anything Goos, from DCC to give it some wear and tear.
I have also made a artillery piece, for my attaching forces. This camo is all procedural.
Here is an update of my thinking for one of my entries (the one to include the cyclopstritch). An army (toonish) with more modern weapons will be losing to a paranormal army with primitive weapons. Here, the paranormal army is created using the non-photoreal renderer and Ron's scratches. The more modern army used the photoreal renderer. Used multipass to combine them in Photoshop Elements. Will clutter up the scene with more of the same of each in the background (and some replicated dead bodies).
I think that this is as far as I can go with this in Carrara with the knowledge I currently have. I do have a question, is there a way to turn off the shadows to the skeletons? They are replicated, and I have shadows turned off on the replicators themselves however, the option to turn off the shadows is not available if I choose the skeleton.
looks good bytescapes - thanks for the tip on the stonemason gear - so it works in carrara ? !
Ice Dragon Art - really picking up Carrara well, congrats!
If you can select the model of the skeleton in the instances list - not the Skeleton - then at the top right under the General tab, you get an option to turn off shadows.
(Ps dont forget to turn off ambient lighting as well (Click Scene in the instances list) - as the ambient lighting is set to 20 percent by fault.
Thank you I will give that a try. I need to crop it a bit closer as well. Worst case scenerio I will remove the shadows with postwork but I want to do as much as possible inside the prgoram.
Yep, Modular Sci-Fi Kit seems to work pretty well. The spaceship is mostly made from two pieces -- a "wall cap" and a floor piece -- that were just added to Carrara 'as-is'. I didn't even change the texturing. That particular set from Stonemason is pretty sweet; I use it in a lot of my images. For example, here's that wall cap again, this time in a DAZ Studio Iray image. If you don't have it, I recommend grabbing it the next time Stonemason's stuff goes on sale.
I'm feeling the deadline. Might have too many replications of the cyclops cavalry to finish my integration of the NPR render. But here are the dead bodies.
Thanks, Mark. Like you, I am trying to get my second going. I am starting a render of my Operation Market Garden entry so that it runs while I go to a watering hole watch the (American) football playoffs. Just hoping that I don't have any giant blemishes because there won't be time for much in the way of corrections.
Cool images! Yes, it is a useful set, from memory any glowing materials need to be set up by hand, but that is not a huge task, and you can set up a folder in your "MyObjects" folder and save them, ready textured for reuse.
Entry Thread Closes/Voting Begins: 12.00 Midnight Monday 17 Jan 2017
Voting Ends: Saturday 23 Jan 2017
FYI:
Just noticed that,
Saturday 10 Jan 2017 does not fall on Saturday. It falls on Tuesday. Monday 17 Jan 2017 does not fall on Monday. It falls on Tuesday. Saturday 23 Jan 2017 does not fall on Saturday. It falls on Monday.
Thought I'd take a look at all the cool renders. I've been off modeling an antlike critter to replicate. Hopefully I'll have it done tonight/early morn and I can move on to adding shader domains which should show the eyes and a bit of difference in legs etc. Would have been done a few days ago with the critter but ran into problems and had a lot of do overs for legs... back ones were a piece of cake, hah, but as you can see are much skinnier than the others... go ahead laugh... I am.
Scene and Questions: I'm planning on having 2 armies of ants, one red the other black coming together in battle. In order to do this I'm thinking that I'll need 2 different maps set to white to distribute each on. Can I have different maps for diff replicaters? Thinking of creating 1 sorta half circle meeting mid terrain... saving it then... flipping the image, mirror, and renaming it to use for other replicater. Sound like a plan?
Hi wgdjohn. The ant's legs look very good to me. No laughing. Serious thumbs up. We are often our own worst critics when it comes to that sort of thing because we know where we struggled.
RE: the distribution maps for the replicators. Yes, you will probably want a separate map to place each army if they are streaming into your terrain from different directions. Or, you could replicate pairs of fighting ants (one red and one black) by grouping two together, then replicate the group to a single map. Or, you might want one replicator for the battling pairs and another replicator for each army streaming into the area. My WIP just above here has separate surface replicators for the cyclopstritch cavalry in the distance, the dead bodies, and the fleeing infantry.
EDIT: If your terrain is flat, you could also replicate on separate vertex grids. Place the grids where you want each grouping. Just remember to turn off visibility and shadows for the grids..
Two more days got to get back to Vertex Modeler.
Sonja, nice job!
once you get a bit of texture on it it will sparkle :)
Varsel, that scene setup is EPIC! Can't wait to see the final render. But watch out, that royal guard is likely to choke on his dinner.
I'm just not happy with my composited entry. The lighting change is too sharp - I inadvertently created a noticeable ring. My attempts to fix it just keep making it worse. And my blend of the NPR and the regular render keeps excluding the cavalry lances.
So, I am gong back to the entry thread and putting the straight render back in. Substitutions have been permitted up to the deadline in the past. Namtar, if this is a problem I can put the original submission back.
I like him too. I made some copying of his works in my childhood.
Excellent tank and crew!
Here is a wip off the final setup.
Still to add some soldiers.
The explosion from the grenade is made out of two sphere primitives, with a Explode Modifier. And a Fire Primitive.
I am also using a Primvol Fog and Rising Smoke.
diomede : my poor royal guard. Beeing over-run by an one-eyed ostrich.
Nybras!
how much time is left?
panic alert
cyclops ostrich the cute
Dates to Remember:
WIP Thread Opens: Friday 23 Dec 2016
Entry Thread Opens: Saturday 10 Jan 2017
breathe fheew
mostly harmless
thanks for the fish
@diomed - love your sense of humour - and it's good to see the NPR being used.
@Varsel, - above and beyond the call of duty!
you can render with and without shadows turned on in the r ender room too
Thank you!
This is looking fantastic @diomede!
I know what you mean about the deadline - I have final high-quality render of my second entry going right now and I feel like it is taking forever!
FYI:
Just noticed that,
Just sayin'.
Wow, thanks de3an! Never noticed.
Here are the render passes for my first entry out of Carrara and the final image. Slightly different camera angle from previous.
Sonja, nice job!
Diomede, this is superb, congrats!!
Here is the requered setup picture, with the replicators.
And the menu for the victory party is ready.....
Roasted ostrich ...
And your all invited.
