Look at my Hair: official thread [Commercial] RELEASED!
1353638404150
  • DisparateDreamerDisparateDreamer Posts: 2,520
    Just want to say.... if you are trying to save some memory, sometimes it is a good idea to use thicker hair and less of them! For that cat for example, you may want to do that.
    One thing I personally do for animals, I make a a shorter, thicker hair coat and then a longer, thinner, and a bit less dense outer coat. Many animals have hair like this in real life anyway. :) Sometimes it is faster than a million thin hair strands. ;)
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,650
    Agreed 100%!
  • KatteyKattey Posts: 2,899
    It isn't just about rendering times, it is also about the look. Hair I created so far doesn't really look that good as on promos, regardless of what I try.
  • Kendall SearsKendall Sears Posts: 2,995
    Hi Kattey,
    What do you feel that you are lacking in quality that exists in the images you are comparing against? LAMH has a lot of settings that can effect many different results. Is your hair too thin, or not styled the way you'd like, or ...
    Could you give some examples of what you're getting vs what you'd like to get?
    Kendall
  • SotoSoto Posts: 1,450
    Kattey said:
    Question: do people use shadowmapped lights, raytraced lights or/and uberenvironment lights?
    Shadow map is much more faster than Raytraced. I never used Uber Environment that much.
    What I'm using now, and I love it, is the Point-Based Occlusion from the Scripted 3Dlight (render settings) So I don't even have to use shadows or additional lights and it looks really nice. Slower than regular lights with shadow map, but faster than Uber Environment and without noise.
  • clayphdclayphd Posts: 7
    How do you use the Scripted 3Dlight? I tried to look for info on it but never found anything.
    First worry is rendertime. To use raytracing and/or uberenvironment takes at least 40 minutes to render a simple small portrait (hair take 10% of frame) with amount of hair suggested here (120K) which, with i7 CPU and 8G of RAM should be faster, judging from other people times. I should use shadowmaps to speed up the process but I would like not to.
    Second worry is that hair looks just dull. It doesn't shine, it doesn't look like hair or fur, doesn't look like anything on promos, really. I didn't find manual helpful in that respect either, sorry.
    I'd second that question. This is the first time I ever hear about scripted 3Dlight.
    Kattey would you like email me a preset that you've done that doesn't render as you expected? Maybe I can take a look at it and try myself...
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,039
    using the figure set up tab I rigged the fur with the milcat bones but forgot the cat!
    800 x 800 - 7M
    Oh well, that's a ghost cat! :)
    Sure, hair preset or my rendering parameters or something else?
    ooh yes, make the fur white and it would be a really good ghost cat.
    Just the .lmh zipped file would be fine: then I'd try to render it myself and see the results.
    My email is: info_at_alessandromastronardi.com (replace _at_ with @ ).
    Thanks
    Render Settings - Render Engine- Scripted 3Delight - Point-Based Occlusion
    Then you get some render setting you can play with. Personally I just go to the Point-Based section and select:
    Hit Sides: BOTH
    Clamp: On
    BTW: Claud Shading Rate: less = better/slower
  • RarethRareth Posts: 1,462
    I use Raytraced shadows with shadow bias at 0.1 average render times around 10 minutes or less.
    excuse the cross eyed expression, Vicky's a bit stressed due to the season.
    1356 x 1017 - 306K
  • Mari-AnneMari-Anne Posts: 363
    Hiya Alessandro - I have a "timid" question. Will you be having any demo videos where you talk? Being totally new to the LAMH program, I'm having a dickens of a time trying to follow your mouse as well as the explanation text.
    Hi Mari-Anne, you mean that you prefer videos with voice or subtitles? :)
    Nice model Rareth!
    Nice model Rareth!
    thank you, one of the tricks I discovered if using a 3 pt. light set, is turn the intensity down, I use 2 distant lights and 1 linear pt light, the main distant light is usually set at 80% the filler distant light is around 45-50% and the linear pt light for backlight or kicker is around 35%
    raytraced shadows on, shadow biat 0.1 Render Shading rate was 2 for this one..
    Well, if I had my druthers, I'd prefer voice.
    edited December 2012
    Ok, very good because I already started preparing voice tutorials. I wanted those ready for LAMH release but unfortunately I couldn't make it in time. I think I will be able to upload the first batch of tutorial videos within the 27th...
    Post edited by Alessandro Mastronardi on
    here is the same cross eyed vicky rendered with the scripted 3delight settings posted by Hellboy
    1356 x 1017 - 319K
    Sounds very promising - thank you! I'll stay tuned.
  • JaderailJaderail Posts: 0
    Well I have only one thing to say about LAMH. Hot Dang I like this thing.
    How about some tips for counts on the Different sized figures from you folks in the know.
    I have many critters to Fur up, Ranging from Human sized or a bit bigger to rabbits. Any thing to cut done on my tweaking as I go will be a BIG help. Thanks in advanced.
    I'd like to second that. Great idea, 'cause correct me if I'm wrong, I think we still have to specify the count even when we apply one of the presets from Alessandro's site??
    Critters, I dunno about critters, but I am having fun putting hair on people
    1356 x 1017 - 231K
  • smoke14smoke14 Posts: 267
    Hey Alessandro, I really want to thank you for this plugin. I'm just starting to try it out and so far its awesome. Just wanted to show a pic I did of the MilCat with the long hair preset. It is amazing the difference it makes to have the cat to have "real" fur. I'm really looking forward to seeing just what I can do with LAMH.
    1000 x 722 - 97K
    I can promise you, folks, that it's only going to get better.
    Kendall
  • JOdelJOdel Posts: 6,308
    Okay, that feeds right into my question: how do you apply the presets? I've installed and activated, adn it seems to be behaving itself. But although I downloaded most of the presets for animal fur, there don't seem to be any instructions for applying them. There isn't anything in the interface which referred to or obviously related to presets.
    The manual doesn't get into that, either. Needs an addenda which does, since I gather that quite a few people are likely to be building and distributing presets for different models before much longer.
    Which brings up my 2nd question. Where do we store the presets? Anywhere we please and just point the plugin at them, or do they need to be in a specific place.
