Does Fortuna Hair Have Iray Materials?
I absolutely love this beautiful product and have a character that would look fantastic in it, but I only work with Iray.
I only see materials for 3Delight in the description. Does this product not support Iray, or did I miss something?
http://www.daz3d.com/fortuna-hair-for-genesis-3-male-s-and-female-s
  • argel1200argel1200 Posts: 760
    The 3Delight materials should work acceptably well in Iray without modification. Also, http://www.daz3d.com/idg-iray-hair-essentials-shaders might work on Fortuna Hair. Most older hair products translate over fairly well.
  • PipefoxPipefox Posts: 113
    Thank you, argel1200. :) I've found that 3delight hair ends up looking a bit overly shiny in Iray. I do have the hair shader product you mentioned, it's very useful!
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Just go into the surfacing tab and turn the specular down to black or dark gray
    Thank you for the tip, FSMCDesigns! I didn't know about that. I'm going to try it!
  • fastbike1fastbike1 Posts: 4,079
    edited January 2017
    It's more mony, but this product will enable Iray on virtually every hair and will allow a lot of custom work: http://www.daz3d.com/uht2-ultimate-color.
    This set is a bit simpler than Slosh's product but is also a geat Iray hair shader: http://www.daz3d.com/idg-iray-hair-essentials-shaders
    Post edited by fastbike1 on
    Thank you, fastbike1! :D I have the IDG Iray Hair Essential Shader. It's a fantastic product, I use it all the time!
