Does Fortuna Hair Have Iray Materials?
I absolutely love this beautiful product and have a character that would look fantastic in it, but I only work with Iray.
I only see materials for 3Delight in the description. Does this product not support Iray, or did I miss something?
http://www.daz3d.com/fortuna-hair-for-genesis-3-male-s-and-female-s
  • argel1200argel1200 Posts: 760
    The 3Delight materials should work acceptably well in Iray without modification. Also, http://www.daz3d.com/idg-iray-hair-essentials-shaders might work on Fortuna Hair. Most older hair products translate over fairly well.
  • PipefoxPipefox Posts: 113
    Thank you, argel1200. :) I've found that 3delight hair ends up looking a bit overly shiny in Iray. I do have the hair shader product you mentioned, it's very useful!
    Just go into the surfacing tab and turn the specular down to black or dark gray
    Thank you for the tip, FSMCDesigns! I didn't know about that. I'm going to try it!
    edited January 2017
    It's more mony, but this product will enable Iray on virtually every hair and will allow a lot of custom work: http://www.daz3d.com/uht2-ultimate-color.
    This set is a bit simpler than Slosh's product but is also a geat Iray hair shader: http://www.daz3d.com/idg-iray-hair-essentials-shaders
    Post edited by fastbike1 on
    Thank you, fastbike1! :D I have the IDG Iray Hair Essential Shader. It's a fantastic product, I use it all the time!
