Render Studio Iray problem in DS 4.9.3.166
Taoz
Taoz
Yep, I am getting the same thing. Also tried adding smoothing modifier on it, didn't help any. Adding subd made it worse. First one is subd, second one is smoothing.
OK, will file a bug report then...
Happened to the one I made for myself as well, tho not quite as drastic.
Laurie
Hmmmm, maybe the mesh is just too thin. I looked at a bunch of other stuff with smooth curves, and didn't see the same artifact happenning. One thing I found that helps is a little, is turning off thin walled in the surface options.
