High Cliff Crossing Environment - Available Now - [commercial]
FirstBastionFirstBastion Posts: 8,074
edited January 2013 in The Commons
A new large environment. High Cliff Crossing
for both Poser and DAZ Studio.
Available now here at DAZ:
http://www.daz3d.com/high-cliff-crossing
«1
  • adamr001adamr001 Posts: 1,322
    oo, this looks nice!
  • LycanthropeXLycanthropeX Posts: 2,287
    oooooo new FB goodies
    Ignore that whimpering noise, it's only my bank card...
    Hooboy, we could get a real sense of scale and distance with this scene!
  • KharmaKharma Posts: 3,214
    This is awesome. A few days ago I was putting together a scene using the Moongate, and suddenly I realized I had no idea how to put a sky in or a ground cover....so I posted as to how to do this...and now these different environments are becoming available!!! thank you so much to all you artists who spend your time creating these beautiful pieces...I can now put a sky and ground behind my scenes!! I am sure I will be purchasing each and every one of them.
    Thanks again :)
  • ColemanRughColemanRugh Posts: 511
    Great looking set!!
    Wow! Some great sets coming out lately...better check how much I have left on that gift card I bought!
  • FirstBastionFirstBastion Posts: 8,074
    Thank you all for the positive comments.
    Here's a view from upper approach.
    686 x 696 - 465K
    I sooo have renders i want to do with this
    i assume there is quite a bit of modularity with this. your sets can usually be moved around quite a bit
  • ledheadledhead Posts: 1,586
    I love it, but where are the access ramps for the interchange.
    No off ramp on this one, but there's something coming down the pipe that might be of interest. ;-)
    Lycan, you're right, there's modular components that can be easily moved around and/or mixed and matched with other FB sets or any others in the runtime. It's all about an arsenal of meshes that can come in handy in developing an image.
    In the pic below, I shifted the cliffs_east section tighter in to the road, hid the arch bridge and walkways, and used the distant cliffs from the upper approach area to fill the left side of screen. Took all of four minutes.
    (note to self, must go resurrect that mix and match thread. )
    800 x 750 - 416K
    the whole set will probably fit nicely in the Gallerie Bastion
    I don't know, the guard on the bridge in the second image is at zero position, and that looks at least 80-100 feet down to the valley floor path. Unfortunately I had to reinstall my OS to factory default and haven't reinstalled all of my runtime just yet, but I'll definitely install the Gallerie and do a comparative render to see the size difference. One good thing, this entire set is parented so it can easily be resized to whatever dimensions are needed.
    you know, another mix n match would be a lot of fun....
    Another "mix and mash it up" contest? hmmm, that could happen, I could see doing that sometime in the New Year.
    Tried a completely different use for the set. Threw in a basic plane primitive and watered it up. European coastal.
    600 x 436 - 259K
  • JOdelJOdel Posts: 6,322
    And it's gorgeous. Except I can't imagine the Royal Courier service getting horses up and down those stairs...
    Well, I suppose they could do it. But they'd be cursing you all the way.
    The mix with the hidden waterfall is spectacular.
    Beautiful...I threw it into the cart earlier so I wouldn't lose it. Off to check if I can afford it...
    Thanks for the comments. I think you may have a point about the horses! Didn't consider it until you mentioned it. Perhaps there's stables just off to the side, and the rider changes mounts after a short stroll for the next lag of the journey, ( I'm just thinking aloud :-) ).
    I'm going to do a quick tutorial on how to get this HCC set lineup with the Hidden Waterfalls to produce the picture. Since the entire set is parented it is really simple to just move it into place. And then it's just a question to hide or remove the parts that are overlapping.
    1100 x 550 - 416K
  • IvyIvy Posts: 7,165
    thanks FirstBastion for making this great model in PP2 file format.. I'm going to be using this in my upcoming film I am working on.
    great stuff :)
    1920 x 1080 - 248K
    Looking forward to see the movie Ivy.
    I figure I'll add this promo, somehow got left off the product page. One of the many camera angles, it gives a sense of the steepness of the lower road.
    700 x 393 - 372K
  • jmperjmper Posts: 261
    Makes for a nice cold place.
    1644 x 1071 - 454K
    Is that Draagonstorm's snow shader?
    Looks very cool! ; )
    Snarly gribbly's snow machine
    jmper that looks great! I really like the sense of thickness and depth that script produces. It'd be great if a set of tire tracks could be displaced into the snow.,
    In case anyone's looking for the snow machine script: http://snarlygribbly.org/3d/forum/
    No worries...I think I could probably get the snow shader to do the same in DS. I 'll have to try when I put the order through...it's sitting there in the cart waiting for me to be able to afford it.
    That Poser only, or does it work in Studio?
    Thanks...of course it takes a real nice environment to look good!
    Tracks would be awesome as well. :)
    Poser only I'm afraid. Uses Python scripting.
