Shaping Tab stays empty
Hey there,
I'm pretty new to the program but already got some good renders. My problem: For no apparent reason there are no more options in the Shaping tab, like body and face morphs. They were there before, and I can access them still via Parameter - Actor, but it's really annoying. Up to three hours ago, it was fine, and I've used DAZ since the update so I don't think it is related.
So far I have un- and reinstalled DAZ3D and G3F Body & Head Morphs via DIM and reset the database, to no effect. Is this a bug or am I overlooking something?
Cheers
Arne
  • Uninstalling DS certainly won't help an issue like this, if nothing is showing in the shaping pane it's unlikely to be the particular morph set. The CMS might be involved, but most likely is a setting in the Shaping pane. Please post a screenshot showing the two panes (and not showing the figure unless she has clothes on or the display is set to a non-textured view).
  • arne207arne207 Posts: 165
    OK, hang on a moment. With the two panes, you mean Shaping and Parameters?
    This is the empty Shaping pane...
    1920 x 1200 - 382K
    ... and this Parameters - Actor. It shows some of the morphs that are available for the arms which used to be available via Shaping.
    1920 x 1200 - 415K
  • The Shaping pane is showing the Presets tab, switch to the Editor tab and you should see the sliders.
    God, I feel stupid now. Thanks Richard!
  • Hey there. I have the exact same problem, BUT the shaping options are not showing up ANYWHERE. They are not under the editor tab (people always seem to find that to be their solution), they are not under the parameters tab. I am not able to shape any figure, nor can I change their facial expressions. All of my shaping options are simply GONE. Please help and thank you.
