Elven Armor for Genesis 2 Female(s)'s hip plates' problem
nDelphi
I am wondering if I am the only one seeing a problem with the Elven Armor for Genesis 2 Female(s) hip plates? I haven't use the armor in awhile so I have no idea if this is an issue with the new DAZ Studio. I did uninstall and reinstall the armor just in case. I install everything thru DIM. The problem is only with the hip plates.
2017-01-05 10:58:12.268 WARNING: fileinput\dzassetdaz.cpp(4576): Could not find node parent.
2017-01-05 10:58:12.288 WARNING: fileinput\dzassetdaz.cpp(10852): UV set: "/data/Valandar/ElvenArmor/Hipplate/UV%20Sets/Valandar/Base/default.dsf#default" has wrong vertex/facet count
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1868): Could not find UVs for geometry.
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1307): Failed to create uv set!
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(4726): Could not find geometry for the material instance.m_uri.
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1326): Failed to create material!
2017-01-05 10:58:12.297 WARNING: fileinput\dzassetdaz.cpp(1326): Failed to create material!
2017-01-05 10:58:12.297 WARNING: fileinput\dzassetdaz.cpp(4726): Could not find geometry for the material instance.m_uri.
2017-01-05 10:58:12.304 WARNING: fileinput\dzassetdaz.cpp(1724): Failed to follow node.
2017-01-05 10:58:12.304 File loaded in 0 min 0.2 sec.
2017-01-05 10:58:12.305 Loaded file: Elven_HipPlates.duf
2017-01-05 10:58:12.376 WARNING: libpng warning: iCCP: known incorrect sRGB profile
I reported this, this product was working fine. I think it has something to do with the latest DAZ Studio (4.9.3.166).
That's... odd. And it didn't start doing that until recently? I know it didn't do that with earlier versions...
Worked fine before, I was waiting for this latest version of DAZ Stduio because I want to finish a render that takes a lot of memory and I wanted to do it with my GTX 1080, my GTX 960 doesn't have enough memory and I don't do CPU renders anymore.
This is the unfinished render. As you can see the Elven Armor was working fine.
I've let them know. It's something that happened on DAZ's end, so there's not really much I can do.
