Elven Armor for Genesis 2 Female(s)'s hip plates' problem
nDelphinDelphi Posts: 1,974
I am wondering if I am the only one seeing a problem with the Elven Armor for Genesis 2 Female(s) hip plates? I haven't use the armor in awhile so I have no idea if this is an issue with the new DAZ Studio. I did uninstall and reinstall the armor just in case. I install everything thru DIM. The problem is only with the hip plates.
2017-01-05 10:58:12.268 WARNING: fileinput\dzassetdaz.cpp(4576): Could not find node parent.
2017-01-05 10:58:12.288 WARNING: fileinput\dzassetdaz.cpp(10852): UV set: "/data/Valandar/ElvenArmor/Hipplate/UV%20Sets/Valandar/Base/default.dsf#default" has wrong vertex/facet count
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1868): Could not find UVs for geometry.
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1307): Failed to create uv set!
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(4726): Could not find geometry for the material instance.m_uri.
2017-01-05 10:58:12.293 WARNING: fileinput\dzassetdaz.cpp(1326): Failed to create material!
2017-01-05 10:58:12.297 WARNING: fileinput\dzassetdaz.cpp(1326): Failed to create material!
2017-01-05 10:58:12.297 WARNING: fileinput\dzassetdaz.cpp(4726): Could not find geometry for the material instance.m_uri.
2017-01-05 10:58:12.304 WARNING: fileinput\dzassetdaz.cpp(1724): Failed to follow node.
2017-01-05 10:58:12.304 File loaded in 0 min 0.2 sec.
2017-01-05 10:58:12.305 Loaded file: Elven_HipPlates.duf
2017-01-05 10:58:12.376 WARNING: libpng warning: iCCP: known incorrect sRGB profile
  • nDelphinDelphi Posts: 1,974
    edited January 2017
    I reported this, this product was working fine. I think it has something to do with the latest DAZ Studio (4.9.3.166).
    Post edited by nDelphi on
  • ValandarValandar Posts: 1,418
    That's... odd. And it didn't start doing that until recently? I know it didn't do that with earlier versions...
    Worked fine before, I was waiting for this latest version of DAZ Stduio because I want to finish a render that takes a lot of memory and I wanted to do it with my GTX 1080, my GTX 960 doesn't have enough memory and I don't do CPU renders anymore.
    This is the unfinished render. As you can see the Elven Armor was working fine.
    900 x 900 - 395K
    I've let them know. It's something that happened on DAZ's end, so there's not really much I can do.
