Show us your 3Delight renders
Adding to Cart…
Heh heh.
Playing around with LAMH... here's Genesis Troll with the freebie primate fur from the site
Here's a test render for StrangeFate's as yet unreleased fantasy armor named Kadis
Good point!
I haven't tested this with shader mixer stuff, though. It's all so damn fragile, as you know.
I'll just stick my fingers in my ears and pretend I don't know anyone who is _not_ using linear workflow LOL La, la, la...
In all honesty, folks, Mike is right.
This thread started by Parris isn't sticky "just 'cause", it's really important if you want to minimise those "what the hell" moments: www.daz3d.com/forums/discussion/54913/approaching-realism-in-daz-studio-and-gamma-correction-demystified
This is so cute =) And quite nice for the "very first render" in terms of lighting!
These characters are full of... character. =) They'd make fitting adversaries.
She's looks pretty great in that Bastion.
Another character.
Love the mummy in the background, nicely done.
-- Walt Sterdan
that came out really nice, I had looked at the little guy when deciding for my freebies but decided for something else as the fur seemed not as convincing, now I never played with LAMH ( only have the free player anyway) but this makes a huge difference. Nice DOF by the way.
I played again with an underwater scene. there is some render artifact on her belly that only happened in the large scale render I made of it and therefore notied far too late. I decided to ignore it for now but I was wondering what happenend there.
I pretty much always feel this way! HA!
...that looks just as good as a number pics Ive seen rendered in Iray. Is the raytrace GI script something that is available (not really up on scripting myself)?
I'm loving the holiday free stuff!
Here are two items I got...
Tha is a neat render Will, I had that turle so many times on my list for the freebie choice but yet evrtime something else won.
Hehe..cute.
Sweet =)
Could the artefact be related to the blend between the body and the tail? Some transparency gone wrong. Have you checked if the map got a 1 or a "0" gamma correction value assigned?
If you ever decide to re-render, may I suggest you try adding a cookie light with a caustic texture? There is a non-commercial caustic generator here: https://www.dualheights.se/caustics/
All my renders are 3Delight. With no nvidia graphics card iray is not a viable option for me. I used to do a lot (as in I have several worn out cameras) of B&W photography because I used to enjoy darkroom work. Realism was, however, never a prime requirement of my photography. Unfortunately health issues now mostly preclude photography and so I make renders. Here's a recent effort.
I have been thinking that it might be the body tail transition, I just would have expexted that it shows in the test renders as well. Where do I check for gamma correction value? I have not see that type in the surfaces tab
Thanks for the link to the caustics generator, I will try to understand that thing during the upcoming holidays. I ewas trying to emulate some caustics by giving the water surface a displacement map and a refraction value but its not as present as i would have liked, it worked better with the bottom of the see.
Thanks a lot... now one could start marvel about whether mermaids are mammals as well or not...
Trying out Eliot hair, also experimenting some more with getting the skin to look to my satisfaction.
So far I've had good luck with UberSurface2, no SSS, shutting off specular and instead using a teeensy bit of reflection (like 2-3% with about 50% blur, and 10% blur on lips). It's not perfect, but I like the look way better than the skins as is.
I have a couple of renders I have been working on sort of off and on when I get frustrated with them. I am having issues with an animal texture and one character skin (V4). Anyways will post them both are done in 3DL. If I need to remove them for some specific reason it is ok too.
Thanks Barefoot. Yea, there is poke through too on the one item. I am still going to keep working on them. :)
Have you tried using Fresnel? The eyes would really benefit from Fresnel, too. It's "artistic" in the Ubers, not IoR-based. I'm attaching a sort of chart from my mega-tutorial that shows how those values interact.
For US2 skin, I used Fresnel falloffs in the 2...3 range with strengths dialed slightly down (into the 90s), and with a little sharpness added (with 100% Fresnel strength, sharpness generally kills any direct highlight, but with lower strength, even 15% sharpness can look good).
Then you can keep your reflection at white point and 100%.
It's in the "image editor" you get when clicking for a map in the surfaces tab. DS generally guesses fine, but often misunderstands opacity maps and thinks they are colour maps ("0"). They should be linear (1).
It wouldn't give you caustics in 3Delight this way without a few other technical efforts. Besides, VFX professionals make a point of "when you can simulate caustics through a projection light, do it".
Mjc's Anna wearing the Xmas freebie dress by Fisty & Darc, having fun with a few other props from the PA gift thread... custom RSL shaders all the way.
Click for bigger =)
