Cyclopstrich 2 Questions on Morphs and Rigging in Studio
DiomedeDiomede Posts: 15,439
edited January 2017 in Carrara Discussion
Here is a freebie Carrara figure.  Kind of silly, but you get what you pay for.  wink
EDIT:  Discovered a few stray polygons in the beak area.  Should be fixed now.  Zip replaced.
This will be the mount for the cavalry in my upcoming Carrara challenge 30 entry.  Feel free to use in any way you wish.
See attached zip file
Post edited by Diomede on
  • LlynaraLlynara Posts: 4,772
    LOL Thank you! He's adorable! Does he eat much?
  • heart thankyou
  • mmoirmmoir Posts: 836
    Looks like a fun character.
    So cute lol!  Thank you!
  • mindsongmindsong Posts: 1,769
    lol,
    tnx a bunch for the critter!, and a healthy healthy healthy new year to you all. (If you have health, you can work on the happy/prosperous details at your leisure!)
    best wishes and thanks to all for a great 3D year! Y'all rock!
    --ms
  • StezzaStezza Posts: 9,149
    can also double as a Cyclopstemu...
    thanks and Merry Christmas... smiley
  • I read cyclop stem u cheeky and thought WTF?
    CyclopsEmu ahhhhhh laugh
  • DartanbeckDartanbeck Posts: 22,148
    Wow! Christmas just keeps giving, and giving!
    Thank you diomede!!!
    Merry Christmas!
  • DiomedeDiomede Posts: 15,439
    Hey gang, sorry.  I discovered a few stray polygons in the beak.  Should be fixed now.  I have replaced the zip file with an update.
    ...and right on Christmas Day, too! Thanks Santa! :)
    Mmm. yum. The rigging tasted a bit stringy though . . .! wink Seriously though, it's awesome - thanks Diomede.
    Easter eggs'll be in the shops tomorrow . . .
    Will be making a saddle and harness soon if anyone is interested.  I think parenting will be better than attaching to skeleton, but open to suggestions.
    Another challenge to overcome! Sweet! Can't wait to see how you tackle that one!
    edited January 2017
    Hmmm.  Trying to make a conforming saddle and harness for the cyclopstritch.  Should match.  I literally copied the mesh to begin the harness.  And, I copied the bones (plus an extra beyond each) for the skeleton.  When I attach the harness mesh to the harness bones and use "fit to" in order to conform to the cyclopstritch, the mesh of the harness crumples.
    Does "fit to" work wth custom Carrara figures?  Is there a tutorial somewhere?  Seems like it should work.
    I realize that I could simply add the harness to the mesh in the same bone structure, but that usually requires redoing the weightmaps.  Would like to avoid that.
    1602 x 986 - 201K
    1390 x 975 - 173K
    1670 x 951 - 177K
    I can confirm that attaching both the cyclopstritch mesh and the harness mesh to the same bones works.  Still curious about creating items that use the "fi to" function instead of attaching to the same skeleton, if anyone knows.
    1458 x 1014 - 186K
  • VyusurVyusur Posts: 2,235
    Such a cute creature! Diomede, I've not any experience yet of conforming my own pieces of clothes or any similar stuff to my figures, but if so I will share with you.
  • 3DAGE3DAGE Posts: 3,315
    Fit to ,. requires the same skeleton,. that's how conforming clothing works.
    the bone names in the clothing are matched to follow the bones in the figure.
    Thank you, 3DAGE! I will keep it in mind when approach this task.
    Thanks.  In this case, everything should be the same.
    Have the revised cyclopstritch with wings.  Preparing to rig in Studio.
    Have named the polygon groups.  Exported as an obj with the morphs and skinning option checked.  I loaded in Studio but I can't find the morphs to open and close the eyes, etc.
    Am I doing something wrong?
    1492 x 863 - 138K
    1840 x 906 - 166K
    edited January 2017
    Trying to follow the rigging instructions but the menu never appears.  The instructions say to select all of the bones in the hierarchy then right click in the pane to bring up a menu of weightmapping options.  I have tried but no menu appears.
    hh01 rigging instructions weightmap menu never appears where says see illus 9.JPG
    1008 x 929 - 164K
    1257 x 901 - 135K
    The normal way to add morphs to a figure in Daz Studio is by importing a new obj of the shape change and using morph loader pro to add the obj information to the figure. Yeah... PITA compared to just adding them directly in Carrara, but....
    Make sure you're in Edit Mode
    Just trying to help. I've never made my own rigged figure like this. But I think we have to be in weight map edit mode. You should see options for painting and manipulating weight maps. Wow... It's been a while since I've played in DS.
    Thanks, Dart.  Unfortunately, the menu for the options is not appearing when I follow the directions in that Daz wiki
    Putting this older video for general weightmap instead of triax here for further reference.  Older version of Daz, I think.
    https://youtu.be/FOKTIW7anH8
    another resource to add
    Makes sense to link to Rob's channel because it has multiple videos for figure setup
    https://www.youtube.com/channel/UCSBsiYvJ9hFzW5_Y6ndCtkA
    edited January 2017
    Found it!
    As usual, there was a very small step that I had forgotten because I hadn't used the figure setup tools in a while.  I had the pane that contains the joint editor open, but I didn't have it set to the joint editor.  Instead, I had it set to the manipulater tool by default.  It is amazing how easily I forget these simple steps if I haven't used something in a while.  I had to go back through Blondie9999's gingerman tutorial more than once to figure out which step I was missing.  It may be just becase I am more used to it, but I find Carrara's figure setup system much more straightforward.
    800 x 500 - 120K
