Ready ! - mcjA3BodyconF - Slim fit dress ( bodycon ) for Aiko3
mCasualmCasual Posts: 4,604
edited May 2013 in Freebies
Ready !!!
download --> https://sites.google.com/site/mcasualsdazscripts3/mcja3bodyconf
kinda quirky but usable
Post edited by mCasual on
«13
    Looks really good. A 2mm fit is not exactly skin tight, but close enough for me :)
  • mCasualmCasual Posts: 4,604
    edited December 2012
    extreme side-side test
    the skirt is a bit too distant from the thighs, so i may fix this
    1280 x 720 - 226K
    The drape works very well, and covers her modesty. This is really great.
    there will be an "inflate" morph which can be use to tighten the dress
    so, maybe with subdivisions you could go down to 1mm
    in the image below, it's approx. (exactly?) 2mm
    640 x 720 - 112K
    640 x 720 - 118K
    opacity and bump map test
    480 x 480 - 42K
    960 x 1200 - 233K
    Wow, that looks really good, no need for displacement if bump works that well. Great job.
    LuxRender render using Tofusan's plugin ( 64 bit yay )
    1151 x 897 - 1M
    woohoo i posted it just in time for pacific time
    though i screen-captured it at eastern time
    338 x 249 - 28K
    I like that time, another 100 years before it comes round again, I will catch it then if I'm around :)
  • VilianVilian Posts: 281
    Looks amazing! Can't wait for such quality freebie, it really fits Aiko like a glove ^.^
    just in case you missed them, there's a leotard and a swimsuit for Aiko3 over here, there's also tall boots and high heels
    https://sites.google.com/site/mcasualsdazscripts2/
    1000 x 1000 - 147K
    reviewing the 21 significant morphs
    since each morph was created by rebuilding the dress over the morphed Aiko3
    the "bridges" between breasts and legs are always under tension
    PBMRealistic
    PBMStylized
    PBMFullFigure
    PBMMuscular
    PBMYoung
    PBMVoluptuous
    PBMBreastSize1
    PBMBreastSize2
    PBMBreastSize3
    PBMBreastSize4
    PBMBrstNatural
    PBMBrstDiameter
    PBMBrstCleavage
    PBMBreastLift
    PBMChstWidth
    PBMWaistNarrow
    PBMHipSmall
    PBMGluteus
    PBMGluteBig
    PBMGluteSmall
    PBMLwrBdyWidth
    640 x 720 - 606K
    a pose that shows the dress nicely
    i worked a few minutes to have her look very precisely at the camera
    but i moved the camera (because it was behind the mirror)
    and it ended with Aiko-in-the-mirror being the one who looks straight at the camera
    2nd image has a better stare -
    but it's not 100% there yet.
    I thought having the face almost facing the camera and having the eye's axis point at the camera was enough.
    I now suspect there's more to it and will have to search painting/photography courses.
    It took 107 minutes to render this 9999 samples in blender cycles GPU
    Glossy materials and small light sources produce artifacts named 'fireflies', which require long render times to get rid of
    please click on the pic to watch the higher quality version
    or watch it here https://sites.google.com/site/mcasualsdazscripts2/mcja3bodycon/107minutes.png
    640 x 960 - 523K
    900 x 900 - 53K
    the 62 morphs were added to the dress figure using DS 4.5's Morph Loader pro
    i still have to rebuild the special bend morphs for the legs and the collarbones
    400 x 400 - 781K
    Getting very close, a lot of work but worth it I think.
    I am looking forward to thi script, thanks.
    since i don't want to work too hard on this,
    here's are the collar-bend morphs
    some clothes on the market have the corresponding side of the garment that lifts up
    note that for more common arm movements you can freeze the collar bones and avoid this issue
    in other news, the final name for the dress will probably be mcjA3BodyCon
    the second picture shows that the UV map is cylindrical
    the .obj file is built in a manner that will make it easy to create alternate UV maps
    752 x 640 - 39K
    400 x 400 - 602K
    maybe i changed my mind, maybe i'll make this type of collar-bend-morph
    but there's may be consequences,
    for instance, the ''cleavage'' morph need a companion adjustment morph,
    to be used when the collar bones are bent upwards (as shown in the image)
    so you'll get a tight fit, even when the arms are raised high up, but at the cost of adjusting a specialized morph.
    800 x 800 - 84K
    still some issues to fix
    it takes time but in the end its worth it, for the upcoming dresses too
    the walk animation was an FBX from http://www.audiomotion.com/Downloads (non-commercial uses)
    i converted it to BVH using Animeeple (they closed shop) and the SecondLife avatar for Poser
    320 x 240 - 485K
    *stares in silent, drooly amazement*
    (and no, I didn't miss your previous A3 creations - that's why I'm waiting for this one so impatiently ^.^)
    this well-behaved CollarBend morph is a bit odd to build
    i re-build the dress around the posed figure with her arm way up
    when i place the dress (with no collarbend morph on the dress), the dress around the breast is pulled up and suffers poke-trough
    then using the script below, i create a morph to pull the dress down and away
    anyway, it works :) so we're closer to the release but there's still some miles left to the journey
    // DAZ Studio version 4.5.1.6 filetype DAZ Script
    var cbnode = Scene.findNodeByLabel( "jJCMrCollarBend" );
    var cbmesh = cbnode.getObject(0).getCachedGeom();
    var drnode = Scene.findNodeByLabel( "mcjA3BodyconD" );
    var drobj = drnode.getObject(0);
    var drmesh = drobj.getCachedGeom();
    var n = cbmesh.getNumVertices();
    var morphDeltas = new DzMorphDeltas();
    for( i = 0; i < n; i++ )
     cbpos = cbmesh.getVertex( i );
     drpos = drmesh.getVertex( i );
     d = cbpos.subtract( drpos );
     morphDeltas.addDelta( i, d.x, d.y, d.z  );
    var modifier = new DzMorph( morphDeltas );
    modifier.setLabel( "jJCMrCollarBendd" );
    modifier.setName( "jJCMrCollarBendd" );
    drobj.addModifier( modifier );
    background image by Richard Atterer : http://atterer.org/pic/nyc-madison-square-william-seward-broadway-night
    near Flatiron building it's a 20000 pixel wide equirectangular panorama
    1920 x 1080 - 936K
    800 x 1200 - 438K
    1200 x 1200 - 126K
    worked on it a bit today, the issue is, the collar-Bend morph keeps the dress very tight when the collar joint is at it's maximum of 50 degrees, which is great, but when the arm is midway down ( 25 degrees ) there's poke-through, so i ... well there's many ways to cope with that and that's what i'm checking
    800 x 1200 - 479K
    800 x 1200 - 137K
    it's not advancing fast but it's advancing :)
    sorry for the waiting
    here i solved the issue where the left and right collar-bend morphs were "cross-talking"
    500 x 750 - 119K
    A lot of work, but very much appreciated!
    We can wait patiently :)
    just to confirm that some work is being done on the dress
    but due to various xmas reasons it's will take more time than expected ... when was it? ... december 12th :)
    here you can see that when 1 or 2 arms are 100% up, the dress has no poke-trough
    before this last tweak, when 1 arm was up, the other side of the dress had some (very little) poke-trough
    266 x 400 - 600K
  • kjer_99kjer_99 Posts: 40
    Bit slow coming to this thread, but glad to see it. Your work is very, very competent and I always look forward to something new for Aiko3, who is still my all-time favorite DAZ character of any generation. Thanks for all your hard work.
    Jeremy
    Jeremy
    thanks ! i didnt make many clothing items so far but there's over-the-knee-boots, high heel shoes, a leotard and a swimsuit over
    here : https://sites.google.com/site/mcasualsdazscripts2
    all for Aiko3,
    more recentlty, a bustier and a dress similar to this one, for Genesis
    720 x 1280 - 93K
    today's turtle step, the CollarBend morph works for the 0° to 50° collar Up-Down range
    the tightness of the dress at 50° is less perfect but i got rid of the poke-through for other settings
    ( then DS 4.5 crashed ... still suspecting it's due to the windows7 magnifier, but i didnt lose my new script/tools )
    1280 x 720 - 315K
    If I was watching her doing that in real life, I would probably be a bit dissapointed, but I'm old now :)
    Well done, a super effort.
    it's not here yet but i plan ( no i swear ) to get back to it soon
    in the meantime, Happy New Year, and, there's a video featuring the bodycon dress
    VIDEO includes test for a hair/fur/grass generator that will probably be named mcjShaggy
    1280 x 720 - 145K
    edited January 2013
    giving it another go
    here's the reason of the delays
    when Aiko lifts her arms up, i don't want the dress to follow slavishly as if it was glued-on and elastic
    plus, i don't want the dress to become loosened as the collar angle goes from 0 to 50 degrees
    so i'll use, 1 collar-bend-morph plus 3 fit-morphs for angles 12.5° 25° and 37.5°
    and ( finish learning ) use multi-stepped ERCs, or JCMs
    800 x 1024 - 61K
    364 x 600 - 361K
    480 x 270 - 377K
