Chablis for Genesis/V4 question??
ArtXtreme101
Hey all! I seem to have posted like a million times today, but oh well. I had a question. I bought Chablis for Genesis/V4 and the issue I have is that when I click the full character for Genesis, the texture is added, but for the morph (each time it says it's missing). Do I need to get Evolution morphs for genesis or some other thing? It didn't list that on the product info or in the requirements....
Help!!
Thanks!
PS: I also uninstalled it and re-downloaded it and installed it and it still didn't work....
Post edited by ArtXtreme101 on
not had that problem, but i do have the evolution morphs.... so that is likely the issue
It doesn't say it needs them...but it does need the Morphs ++ for V4, so I'd imagine it does need *something* for Genesis.
What's the exact wording of the error message? (if you can't grab that, the info should be in the log file...)
I had the same thing happen to me with Stefan for Genesis. Turn out I was missing the M4 shape for Genesis, which it used. I don't know if Chablis needs V4 shape for Genesis, but that may be something to look into.
i don't have the Gen 4 shapes for Genesis, just Evolution and Creature morphs, and Chablis works fine for me
Has anyone noticed that when rendering Chablis in Reality 2.5 there is a line on the neck. It's very noticeable....
are you talking about a seam line? I don't know how to fix that in Reality. but in 3Delight, you might have luck assigning all the skin to the same sub surface group.
If you have "collect textures" checked in Reality output section, you need to set slider to full size to avoid that seam line
