World Gardens Japan Bundle, can't find it
HorusRa
Anyone know where in Carrara this is located, I've looked just about everywhere and I cannot find it?
I notice there is no wiki file list available, so that didn't help.
Post edited by HorusRa on
you may have to manually add it, look in DIM where it downloaded it to,
I find DIM sticks stuff in weird places if one used a ZIP one would stick it in scenes and the appropriate data folders in the right places
This is a DIM issue, not a Carrara issue - except to the extent Daz is not supporting Carrara enough to make sure that DIM places Carrara items where the DIM user specifies. Please open a support ticket in the Help menu at the top of the forum so that Daz tech people are aware that this is not an isolated incident.
I reported a similar problem. The Daz support response was not satisfactory. See here.
http://www.daz3d.com/forums/discussion/comment/1813546/#Comment_1813546
Reporting it in the forum will not make sure that Daz tech people see it.
Oh, and to find it if you installed using DIM (I am assuming that you did), find your product in the installed list, right click on the product row, and choose "show installed files." Note the file path.
