how can i change figure's face
I recently purchased bodies and faces morphs for G3F, I already download it and it went through. The problem is everytime I click on Head A-E and Body A-E, it does not change anything at all it still remains the same.
  • That looks as if the content is isntalled in the wrong place - I can see the Data folder above the People folder, if everything was in the correct place that would be hidden. Did yiou install manually, with Install Manager or with Connect?
  • Roman_K2Roman_K2 Posts: 1,274
    ...and maybe double-check to ensure that the correct item is selected, in the Scene pane, before you click? I've had a few times -- and for me this went on for a lonnnng time! -- when I would click and click and click, and nothing seemed to be happening, because the "selection" had switched over to something else, and the object that I wanted to work on was no longer highlighted.
