Aslan Theater
thistledownsname
in The Commons
Have to say I'm impressed by this addon. I never forsaw anything of the sort coming from Aslan Court, and it's a wonderful way to put use into a place.
Wow, I just noticed that. Very good work!
Agreed.. !
Saw this and it was an insta-buy!
If I own Asian Court 3, is Asian Court 3 Iray add-on actually required to use this ?
It's don't believe so, it's just that you wont have any of the AC3 Iray settings. If I'm wrong I'm sure someone will correct me :)
I read it as Asian Theatre ...
Still bought it though!
.... .... Wait... you mean it's not?? I read it that way too!! hahahaha
Still would have bought it anyway.
some posters ........ should have seen Specsavers!
To be fair some people referred to the originals as Asian Court.. what's in a name really?
a dotted eye!
more of a gap in an L.
Thirty yrs ago, I'd say clean your typewriter more often.
Thank you, I am so glad you like this :) Jacks stuff is wonderful to add things to :)
Yes you can use the Base Aslan Cout without the Iray shaders, but if you use Iray you may have to adjust the materials a bit :)
As usual, you exceeded excellence. Thanks for the beauty!
It's perfect! :D
filling it could be a problem
click to play video
this was about 4GB in Octane 4 Carrara, I used a relpicator grid and moved the seats to match
in DS you could use instances, it was bare bones as actual nekkid people would break the TOS of here and Youtube!
(and the geografts do not work in Carrara the UV mapping is borked!)
I retextured some things too
but cannot open the curtains in Carrara with the Poser version or even load the D|S one so thats a puzzle I must solve.
I had a quick try in D|S with instances plus but G3M manspreads too much to fit in the seats hence pushing the end ones off
it was also very hard in the openGL viewport to work with the instances to move them I could only navigate the scene grouping like instances and using bounding box
It just fit on my 980ti I doubt a whole theatrefull would
Time for low-res characters and some DoF renders. Just fill the first row then go from there.
Can't wait to try a behind the star/rear stage shot.
One of my favorite things is seeing and older product get an IRay update and this set just takes that whole joy even further! Very cool!
a rather creepy video
I created my own curtain morph BTW as it did not work in Carrara for some reason
Bored to death? Nice video, Octane does a good job.
TY,
I do not have the iray version anyway either
might grab one day if I want to render in D|S
