HeadShop OneClick (WIN) Download Fails
HeadShop OneClick (WIN) Download Fails - I have both the latest 4.9.2.70 Release 64 Bit and the latest 4.9.3.128 Public Beta Release 64 Bit but I only get offered one version of HeadShop OneClick (WIN) to download and it doesn't mention 64 Bit or what version of DAZ Studio is is for.
  • Same Problem here.
  • rono64rono64 Posts: 58
    Same problem, and I even tried a manual install and can't get the plug-in to work, headshop works but does not talk to Daz program.
    Very frustrating install, this should be easier.
  • We've flagged this for Daz
  • Same Problem here....
  • From the developer's own thread I gather that this is a standalone installer, are you downloading that or are you trying to use DIM?
  • Won't download from DIM and store link download is empty....
  • I have download it manuel and in the file i have a Installer. I could be installed it so and it works.
    I have downloaded it manually and cannot get the thing to work in Daz worth a damn.
    The plug in is activated etc, but it won't show up in the edit menu, anyone know how to fix this?
    Spent an entire day trying every trick I know.
  • nonesuch00nonesuch00 Posts: 18,882
    When you install it if you have 64 bit DAZ you enter in your serial number and install it to this path:
    C:\Program Files\DAZ 3D
    DO NOT install it to this path:
    C:\Program Files\DAZ 3D\DAZStudio4
    The plugin is actually just a launcher for the real OneClick program. To launch the plugin you go to the main menu:
    Edit (Alt-E)
    and at the bottom of the menu is the menu entry to start OneClick
    ...likewise similarly if you are using 32 bit DAZ Studio
    You must have DAZ Studio 4.6 or greater and it must be a release version, not a public beta version.
    I have it all where it should be, installer works fine, just will not show up in the menu, I have even re-installed  Postgre SQL-CMS several times, reloaded meta data etc. nothing.
    So I am stumped.
    Ok Solved, I have a modified workspace, and I guess that was doing it, I switched workspace layouts and boom there it was.
  • I tried all of that and it still won't show up in Studio. Even checked the about installed plugins section and it wasn't there.
    Don't make the mistake I made and install it in the location where the DAZ Studio executable is but instead  the directory right above that one, i.e. 'Program Files/DAZ 3D' not 'Program Files/DAZ 3D/DAZStudio4'
    Also reset your UI / Menu layout to DAZ Studio to the default & re-install OneCick.
    Don't forget to un-install OneClick if you need to re-install OneClick.
  • The menu layout inside Daz Studio or the one in the c drive folder?
    In DAz Studio, another user said they had customized their DAZ Studio menu layout & that caused the entry for One Clink in the DAZ Studio menu system not to be made by the install process.
  • I tried it all and it still wont work! Very frustraiting!
    OK, well you need to contact the developer as I said all the things or other buyers noticed. You can get the developer's Skype name & email address from this thread:
    http://www.daz3d.com/forums/discussion/122371/headshop-oneclick-submitted-to-daz-best-in-class-commercial/p4
    Also, that developer contact information is probably in the OneClick Support documents.
    Good luck.
