HeadShop OneClick Submitted to DAZ - Best in Class! (Commercial)
24567…13
  • Couple of new renders
    1300 x 1000 - 664K
    1300 x 1000 - 262K
    1300 x 1000 - 278K
  • nonesuch00nonesuch00 Posts: 18,878
    Those renders bring up the question how good those morphs look
    1. child has neutral expression
    2. lady has smile
    3. man has smile
    2 & 3 should work fine but I am not sure about 1.
    truthfully though those pictures are young enough and without unique noticeable blemishes that the typical DAZ 3D customer product inventory should do fine if higher resolution textures are needed.
    I still think I am buying.
  • kaotkblisskaotkbliss Posts: 2,918
    I have a quick question
    Is this "stand-alone" or do I first need to purchase HeadShop?
  • DigiDotzDigiDotz Posts: 515
    Well -I like the look of this I must say. Beats spinning dials to get a lookalike.
  • I have a quick question
    It IS HeadShop. You only need DAZ Studio to run OneClick.
    1000 x 1300 - 698K
  • RedzRedz Posts: 1,459
    23Cascade said:
    nicstt said:
    And does it output greater than 2048x2048; pointless if it doesn't.
    I can't get excited until you answer this.....
    The current version exports 1024x1024, because it aims of the casual user who in all likelyhood won't have a high-res to begin with. For hard-core users I recommend HeadShop 10.2, which does have 2048x2048 plus a lot more tools.
    Unfortunately on both softwares, I fear that you have once again seriously underestimated the market's expectations, casual or otherwise. 4096 is standard these days, and offered by orlthers such as face gen.
    How is it Headshop when you posted earlier that for more options (larger texture resolution) you need the actual Headshop 10.2 product. so based on what I am reading, OneClick is actually Headshop LITE meaning is has some of the funcionality of the actual Headshop product, but not all and to get all the features you need Headshop 10.2, correct? Or deas OneClick replace Headshop
    Sweet! I don't know what all headshop does, but I assumed it was something to do with making morphs from pictures and if all I need is this software to do the same in 1 click, then it's going in the wishlist asap :)
    Not in the DAZ Store yet but I think author will tell us when it is.
    Yes, at DAZ this will be the only HeadShop you can buy. The point was NOT to create a HeadShop Light, but to eliminate even the slightest possibility of users messing up. This meant to automate everything and simplify user interface through automation. HeadShop 10.2 also had many redundancies with Studio (adding hair, accessories, color - all of which you can do in Studio). We took out redundancies but kept advanced options such as profile, which may be important to a smaller number of users.
    The bottom line is that this product represents a giant leap in performance and ease-of-use.
  • will it auto install in any and all versions of daz or do we have to manually configure it copy paste files of faceshop/headshop into each daz version with each daz update, previously when a new version of either full daz or beta was released we had to copy files into certain folders still using HS9 which is working in the last Daz 4.9 full build but is not showing up in the latest beta and probably same when the new full build comes out so if I want to use HS right now I have to create save in previous Daz full build then start up the new beta so I can use iray with my 1080 cards s yeah would this install into the new beta or the previous full build
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • Are the textures it renders for 3Delight or Iray?
    if the person has a feature which only really shows from the side, like a slight bump in the nose, is there a way to account for that? Or would that have to be done manually afterwards?
    Can we adjust any of the automated markers if we think they need slight alteration?
    Does the generated shape morph and texture get immediately applied to the figure or do we have to save them somewhere and then manually apply them?
  • From the instructions it looks like you have to run an external installer.  It is Windows only or is there a Mac installer as well?
  • info_b3470fa520info_b3470fa520 Posts: 901
    edited November 2016
    cridgit said:
    The error in Studio says invalid runtime, so I'm wondering if this has been tested on systems where DAZ Studio is installed to D: and/or using DAZ Connect where each product has its own runtime. I couldn't find a log file in the app data folder, which is a bit disappointing.
    Can you provide any help, otherwise I'm afraid I'll be returning the product again.
    Thanks
    Caution: HeadShop does not run on beta Studio. Make sure you install to the correct version on your c:drive.
    Post edited by info_b3470fa520 on
    It is WIN only. There will be no Mac versions
    This IS HeadShop, nothing else to purchase
  • AtiAti Posts: 9,208
    Thanks
    I use the public release, no beta. But Daz Studio is on drive D. I cannot install it on drive C. Does that mean it won't work?
    It is a good question. Are you saying that your Program Files folder is on drive d?
    Yes. It's actually E, D is the dvd drive, sorry. :) C is a small SSD, only the operating system is on it.
    Everything else is under E:\Program Files\... or E:\Program Files (x86)
    Even the Windows User directories, Documents directory etc. are on the E drive.
    I'm not at home, and won't be today, so I can't try the actual product, but it is something I really would like to use.
    Thanks.  Wanted to know before I bought and then found that I could not use it.
  • Installation is pretty straightforward. If any questions, please watch the how-to install video here:
    Well, I bought and the DAZ 3D DIM  wont download but DAZ 3D is fixing the installer or something.
    I saw in your video that I should use Genesis 2 as they work better. I hope you continue to work on and improve the product so that it works with as good with Genesis 3. I understand if there are future generations of Genesis that I must buy the product again but Genesis is the current version of Genesis.
  • HavosHavos Posts: 5,705
    I would imagine the main reason that Genesis 2 works better is down to there being more polygons in the Genesis 2 face to try and match the face from the photo, thus making it work the same way in Genesis 3 is not easy.
    Well Genesis 3 was supposed to have actually added more polygons in areas around the lips and eyes and such to improve accuracy of face model shaping and expressions.
    OneClick has its own installer (see movie). No use to try DAZ 3D DIM.
    Yes, it does work also with Gensis 3 Base (Male and Female). It is optimized for Gen 2, but will work with Gen 3 too. I would recommend to use unmorphed figures, such as Genesis Base instead of morphs like Victoria and Michael.
    OK, thank you.
  • larsmidnattlarsmidnatt Posts: 4,511
    I decided to give this a try. edit..wait a min i think i got it to work..
    Post edited by larsmidnatt on
  • I'm on the fence about getting this primarily because I have more content for, and like to use, Genesis over Genesis 2.
    Is there a way to transfer the morphs or textures that HeadShop produces so that I can use them on a Genesis figure? If so, I'll get this right away.
    That would be the GenX2 product lines:
    http://www.daz3d.com/dimension3d
